4 members (Robert Crandall, mick53, Danielbolt, 1 invisible), 165 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,456
I was rebuilding the rear mounts for1951 3100 cab.
I was checking to see if Grade 5 bolts are okay to use.
Also does anyone know the length of the bolts used on the rear cab mounts the old ones are gone.
Miller - The 1947-54 FAM says those bolts securing the rear cab mount to the frame and cab floor brace are common hex head bolts, GM# 120233. From what I could track down, the dimensions for those bolts are 7/16-14 x1 1/8" bolts and should be accompanied with 7/16" split lock washers. I couldn't find a designated bolt grade, but think at a minimum a Grade 5 is needed. Just to be on the safe side a Grade 8 wouldn't hurt.
Hope this is helpful. smile
~ Dan
1951 Chevy 3 window 3100
I added seat/lap belts in my 57 3200 and grade 8 were required. It would seem silly to attach a grade 8 seatbelt to a grade 5 cab! frown
1957 Chevy 3200
Daily Driver
PS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated, LED headlights/taillights/backup lights/interior courtesy lights.
Follow in the DITY
Thanks for the info after looking at the 7/16 -14 were to big had to go with 3/8-16 to fit right.
Which bolts are you referring to? The ones which go through the rubber or the ones which go through the frame?
