5 members (rfs56trk, 55shaker, DadsFirstPickup, JoergK., 1 invisible), 324 guests, and 3 robots.
Topics128,152
Posts1,057,011
Members48,460
Should I mount the seat over the new carpet or cut holes larger enough for the seat floor mounts or go strait onto the the carpet with the bolts?
Edit by Moderator: I removed your post from your previous thread and started a new thread.
It’s always better to start a new thread if you have a new question not related to the original issue, so it will get the attention it deserves. The title will draw in more ‘bolters to answer you question
1953 Chevy 153A 3/4-ton
Working on my project since 2015
Follow along in my DITY
AD Addict & Tinkerer
If you try to just drill a hole thru the carpet, the bit will grab the carpet threads and start to unravel them from the carpet leaving a very unsightly hole.
I would place the seat in it’s permanent position, mark where the holes are to be, then use a gasket punch to make very clean bigger holes, allowing the bolts to pass thru without interference.
Alternately, you could use a utility knife with a new blade.
Phil
Project Journals
Stovebolt Gallery Forum
back yard wrench turner
I found that a hot soldering iron will make perfect holes in the carpet for the seat bolts. It melts the fibers and they don't fray.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Great idea Wayne!
Phil
Project Journals
I used a wooden skewer to poke up thru the existing holes in the floorboard to the seat bracket holes and carpet.
Soldering iron is a good idea.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
I guess the method would depend on whether the new floor has been drilled already.
Phil
Project Journals
Yeah, a new floor was not in my suggestion. dang smile
~ BD.
A drift punch of the appropriate diameter, heated up with a propane torch is a splendid way to make clean holes in carpet.
Yeah it would.New floor?
~ BD.
Yes new footboard & floorboard. Holes drilled & seat positioned, bolts in. Removed to upholster the seat. I have the springs repaired & replaced others. It’s painted so hopefully upholster it tomorrow. I started removing & figuring out what to do & how to proceed back around the 1 st of June! I’ll post pictures tomorrow.
Good ideas on putting the holes in the carpet!
I’ve got the burlap on& a sticky back thin carpet over that. The 2 inch foam looks too thick to allow the back rest to move over it.
Should I order 1 inch or just not attempt to put the foam under the back?
I could split (thin it out) it at the back seat? The outside end higher than the center section.
Just adding that I did remove the back seat, trimmed the foam thinner.
The cover sure has a lot of excess material in the back, if I have it turned correctly (front to back)?
Looks like crap! I know it should not be like this??
I used these C clips instead of hog rings.
Came out nice.
https://classicparts.com/1936-72-se...qKS8MoQVe-bQilgscTrLg2oac3PWBRtiPZW6Qx19
~Charley
1954 Chevy 3100 with 235
“Bud”
Follow along in the DITY
1963 Chevy half ton stepside short box 230
1954 GMC 3 ton 302
And several more Chevy camper and work trucks 1979 1987 1996
I had wondered where I could get some of those. I’m pretty sure I have it on backwards but I’m not removing it now. I’ll find some vinyl & cover the front springs.
Moderated by  ndkid275, Phak1
