1 members (Peggy M), 95 guests, and 1 robot.
Topics128,101
Posts1,056,182
Members48,436
Junior Member
Junior Member
I used my H.F. sandblaster the other day,the instructions on "watch out" were not in the package.
Double clamp the bottom hose-to -tank! when she blows off........The clamps they give you are
MickyMouse.
And when the Air Guage reads ZERO dont belive it!!!
You wouldent think that 2 lb top could fly
5' in the air!
I did have a good face shield,ear protection,and a
hard hat on.
Wick
Every Hour you spend Fishing adds
A Day to your Life!
wick37,
Is the offending sandblaster a pressure pot style. I thought the industry standard on the top, or fill hole, was to have it constructed so it was 'inside' the pot and would only open by falling inward with zero internal pressure.
Stuart
Junior Member
Junior Member
Its a pressure feed,you pressureize the tank with the sand in it.You unscrew the cap to put the sand
in it. Only a month old.
A Day to your Life!
wick37,
Is this the '40 pound Abrasive Blaster'! I'm not too anal in these regards, but that screw on top is scary! I'm actually surprised it was allowed to be sold in the good old USA. I can see how your accident happened. Pretty hard to fill with sand too.
Stuart
Pressurized containers can be a danger. Always be cautious. Always check your tools and equipment before and after using. Keep well maintained. Discard worn or broken tools and equipment.
Junior Member
Junior Member
Yea its the 40 pounder!
A Day to your Life!
Good old Harbor Freight.I have very little faith in their products.When I walk thru their store most of the stuff looks like junk.Nothing I would want in my shop.I will occasionally buy a pack of sandpaper,or sanding discs there but thats it.I learned many years ago that good tools and equipment do not come cheap.Possibly something like an engine stand where you can ck.the quality of the welds and construction,but beware,most of their stuff is not worth bringing home.There are good imported tools available.Harbor Freight sells the lousy cheap imported stuff.
harbor freight , you probabaly got a friday afternoon one on EGG ROLL day .....lol
1952 Chevy Shortbed
Photos in Photobucket
mine the hose has come loose and got me on both endes also took a while to find an oriface that wont plug up finly got it tuned in and works good but realy goes threw the sand
Z
Z Offline
Be sure you don't use beach sand, its a killer. The pounded dust from it can cause baaaad lung problems like the old miners used to get.
Buy packaged, tested media such as garnet, glass or plastic beads from a reputable supplier..
"After you skin yer knuckles, Mr Shifter ain't yer friend any more."
1942 Chevy 3/4 ton
Photo Site
1946 Chevy 5 window coupe/ute (new stray)
2000 Nissan Patrol 4x4 4.5l turbo diesel
Moderated by  MNSmith
