0 members (), 110 guests, and 4 robots.
Topics128,183
Posts1,057,264
Members48,467
What is the heater hose size on a 1958 deluxe heater. Are both the same? What kind of valve for temp control goes on the cable from the lever on dash and where is that valve located. Thankyou.
The 1958 TRI-FECTA
Stepside, Fleetside and Cameo
More Fleetside pix
More Cameo pix
More Apache Stepside pix
Pete - For starters, check out this 1957 Chevrolet Accessory Installation Reference Manual. Page 108 is where the Truck Deluxe heater instructions begin. Even thought it's for 1957, it should still cover your 1958. wink
It doesn't specify the hose sizes in there, but a 1929-57 Chevy Master Parts book calls for both 5/8" and 3/4" ID hoses, cut from bulk stock. You should be able to measure the differences in the heater core tubes to match hose to tube sizes.
On the temperature control valve, temps are controlled by a Ranco valve assembly.
This 10+ year old thread by fellow Bolter hd4unm Deluxe Heater Assembly and Installation Tutorial on his 1959 Apache should provide you most everything you need concerning what goes where, how, why, etc. He did a pretty outstanding job creating a detailed "pictorial" to help fellow Bolters with this task. thumbs_up
Need more help???
~ Dan
1951 Chevy 3 window 3100
Thank you Dan. Only had truck a month and drove 4 miles today ( longest drive since I got it. ) I had water coming onto floor from behind the heater. My first thought was a bad heater core , but when I looked under hood , bothe heater hoses wear same size, 1 inch outside diameter, Making me wonder if they were suppose to be two sizes like on 60s models and maybe the new hoses Precious owner may have just crimped down the new hoses onto the heater connection and the longer drive increase heat and pressure and the connection failed. Other heater core leaks I’ve had on other taskforce teucks were small and leaked out of heater housing. Guess I’ll pull it out and investigate. Probably had half gallon pour out while truck was idling b4 turning off. No leak while just sitting.
The 1958 TRI-FECTA
More Fleetside pix
More Cameo pix
Pete - Do you have a Ranco valve on your heater? If the leak you are experiencing is not from the hoses, that's the next suspect place to look. Hope it's just improper hoses and an easy fix. wink
~ Dan
If your heater control valve is broken, these two guys rebuild them and/or sell rebuilt ones.
Rebuilder of Ranco and RobertShaw heater valves. New Ranco heater valves for sale
Joe Hudacek
6606 Banks Avenue
Superior, Wisconsin 54880
715-392-6169
Cell: 218-213-8906
http://www.heatervalves.net/
Rebuilder of Harrison and Ranco heater control valves. New valves for sale 1950 -1975
Jim Tucker
29597 Paso Robles Road
Valley Center, California 92082
760-749-3488
https://www.heatercontrolvalve.com/ (Mod Note: Per bolter Kevinski, Jim Tucker's site shows he passed away 03/2025. No mention of anyone continuing the business.)
1950 Chevrolet 3100 (Ol' Roy)
Just notice on the site Jim Tucker it says that Jim has passed away earlier this year. RIP
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Dang! That sucks. It looks like no one is carrying on with the business since the email and phone number have been deleted.
He rebuilt the valve in Der Bismarck about 20 years ago.
Do I have to remove heater completely to see if leak is fron ranco valve?
The 1958 TRI-FECTA
More Fleetside pix
More Cameo pix
Looks like mine has 3/4 fittings and hoses on both sides and heater core end. Bypassed and joined hoses together. Got to remove heater mow and find the leak. Have to anyway to replace lever on heat control on deluxe controls and see if it’s the ranco. Who sells those if it’s faulty?
The 1958 TRI-FECTA
More Fleetside pix
More Cameo pix
Pete, please see my previous post. Although Jim Tucker has died , the other guy, Joe Hudecek , still sells and rebuilds ranco valves.
Moderated by  ndkid275, Phak1
