5 members (baldeagle, Wally / Montana, CuzzFuzz, kades51, frogfarmer), 31 guests, and 10 robots.
Topics128,020
Posts1,055,345
Members48,419
#1591534 11/08/2025 2:37 AM
Moderator
Moderator
2 Offline
Does anyone know the size of a 1946 3/4-ton Chevy kingpin diameter?
I have a chance to buy a set of adjustable hand reamers at an auction and my 46 needs new kingpins.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
Don - your king pin specs are found in the GM Heritage Center 1946 Chevrolet Truck Data PDF.
Screenshot below highlights the details:
King Pin Diameter = .9210" - .9214"
King Pin Bushings Inner Diameter = .922" - .923"
King Pin Bushings Length = 1 - 17/64"
PS - I moved this to the Driveline forum where it fits best. wink
~ Dan
1951 Chevy 3 window 3100
I have a 0.921" fixed reamer that I used once on my '52 GMC 3/4 ton. You pay the freight both ways.
2-Ton #1591563 11/08/2025 12:36 PM
For what it's worth I used a wheel cylinder brake hone. It didn't take much to get them to size.
51 GMC 100 with 59 chevy 261 under the hood.
3 on the floor with 3.42 gear.
Moderator
Moderator
2 Offline
Thanks Dan, that is just the info I was looking for!
Bill, thanks for the offer but I think I can pick up a whole set of adjustable hand reamers for about the cost of round trip shipping.
Jammer, a cylinder hone is what I was planning to use to finish right to the desired clearance, after the adjustable reamer gets it close.
I’ll be shooting for no more than .001 clearance for a good slip fit.
If I was still working, I would make them myself.
Don
"The Flag Pole"
1953 1-ton pickup
The correct guided reamer that Bill offered above is what you need. .921 is correct. I did mine a few years ago and my 41 ford with same type of tool but different size and it does a great job. Basically the tool is the line bore when you can go at it from both sides.
I found both on ebay for pretty cheap. All I did was find correct part number from a early magazine and it popped right up.
Originally Posted by 2-Ton
I’ll be shooting for no more than .100 clearance for a good slip fit.
I think you have the zeroes in the wrong place.
2-Ton #1591594 11/08/2025 11:50 PM
Moderator
Moderator
2 Offline
Thanks Bill for pointing that out. And yes, I did type that wrong earlier today. It should be .001 tolerance.
This getting older has it's new challenges! Edit will be next.
Don
"The Flag Pole"
1953 1-ton pickup
2-Ton #1591598 11/09/2025 12:23 AM
I often have a problem we used to call "a short between the keyboard and my chair".
Moderator
Moderator
2 Offline
Bill, I look at it as live entertainment and it’s starting to happen more often with about anything I do. I just laugh it off and move on.
Don
"The Flag Pole"
1953 1-ton pickup
