0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
Since I’m replace front leaf springs. I can’t find the torque requirement for the Ubolts that hold the axle to the springs or how tight the front shackle (name?) bolts should be. Previously, I think I over tightened them and destroyed the rubber bushing/seal.
Chris
Ps I prefer to use something more specific than 2 grunts of torque.
In the text for spring and u-bolt installation in the service manual, it just says "tighten securely", but I just found the torque specs on page 4-48 of the 48-51 Service Manual.
Rear U-bolts: 1/2 ton 75-90 ft lb, 3/4 thru 1-1/2 ton 210-235 ft lb, 2 ton 375-400 ft lb (sure glad I don't have a 2-ton wink ) I went with 100 ft lb on my 51 3100
Front U-bolts (page 3-13) same on 1/2 ton, 3/4 ton thru 2 ton 125-150 ft lb.
I didn't find shackle bolt torque, but I think 25 ft-lb should do it. Again the service manual says "tighten securely", then says smack the shackle arms with a hammer and retighten.
Thank you! I missed that when I looked! My brain is all over the place right now.
Chris
U
U Online: Content
Originally Posted by klhansen
... Again the service manual says "tighten securely", then says smack the shackle arms with a hammer and retighten.
I missed that part. Might need to get the BFH out and do some smacking!
~ John in Utah
Here We Go
Follow in his DITY Bay
If it were an import pickup would you need to use a metric hammer?
No but you'd need to torque the shackle bolts to 34 newton meters. wink
Proper torque = 1/4 turn before you wring it off.
Mike
1951 3100 5 window
My computer is old and acting up so no copy and paste, just google search u-bolt torque. Most all the spring manufacturers have charts on their web sites. Torque values are for the thread diameter, doesn't matter what they go on. 1/2"-20 u-bolt for example, torques to 52-70 ft lbs depending on if its oiled, dry, or plated. After some drive time, they need a re-torque.
if you can wring a "U" bolt off with a 3/4 inch wrench, well thats doing something. Tighten the best you can,
drive it and tighten again.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
I've used the "torque it till it breaks and back off 1/2 turn" technique a time or two. wink I have broken 1/2-inch bolts while torquing them with a 2' lever arm torque wrench, but a 3/4 hex combo wrench would be a bit more than I could do.
OP - Be aware that almost all axle u-bolts are torque to yield, and should not be re-used. Although probably millions have been reused without issue, personally I'd get new ones and torque them according to the fabricator.
Some useful info attached.
Geoff
1955 2nd Series 3600 235 cid, 4 sp. - Current
1979 Chevy K10 350 cid 4 sp -Sold
1955 2nd Series Wide Window 283 cid 3 sp - Totaled
Geoff - For some folks that find having to download a PDF like this troublesome or difficult, I've captured each of the 4 pages of the document as pictures and attached them below for easier viewing.
Thanks for sharing this information! thumbs_up The safety aspect is definitely a good point to bring up. wink
~ Dan
1951 Chevy 3 window 3100
Interesting and useful information there. Never throw away your old U bolts before laying them on top of the new ones.
1950 Chevrolet 3100 (Ol' Roy)
I just found that 1/2 ton is 90 ft/lbs…. Not 120 ft/lbs like I thought.
Last edited by Gdads51; 11/04/2025 8:47 PM. Reason: fixed the image so it displays correctly (was sideways)
1 Offline
Years ago I pulled the front end apart to remove leaves from the front springs. I installed new U-bolts at that time. I don't remember the torque I used but probably a 7/8 socket with a 3/4 drive breaker bar with a length of pipe on it. Years later I would like to take is apart but using the same tool set up, I can't get it to budge. I was stronger when I assembled it... then there's rust. So this time I'll probably just cut them off with the torch... After the new springs come.
1951 3800 1-ton
In the DITY Gallery
