6 members (RAC1812, HandyAndy, Peggy M, 1955 1 Series, Otto Skorzeny, Bill Marlow), 190 guests, and 1 robot.
Topics128,087
Posts1,055,982
Members48,430
#1590949 10/31/2025 10:40 PM
Anyone know the numbers for a 261 carb .I noticed the other day when I was messing with some linkages to try and hook up my carter carb that I have 3 different Rochester carbs .I do know that one came off a 216 as I took it off myself and the bolt pattern is smaller than the one that came off of my 235 the other carb that was a spare to the origional Rochester that came with my truck looks bigger at the bottom and has 5140 stamped on the bottom of the base and 7005606 long the side of the base .The bowl has7005604 .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
KEVINSKI #1590953 10/31/2025 11:11 PM
H Online: Content
Unless you happen to have the triangular sheet metal tag that the carb came with originally, held on by one of the top cover screws- - - - -the one that usually got lost during the first rebuild, identifying a Rochester is a crapshoot. Several main body and throttle body casting numbers were used across a wide variety of very differently calibrated carbs. Carb King has posted a pretty comprehensive list of the various tag numbers, but without the tag number, it's a guessing game.
KEVINSKI #1590962 10/31/2025 11:55 PM
KEVINSKI - Take a look at this Common Rochester B Series Carbs PDF listing in the Engine Shop Tech Tips sub-forum. wink
Those identity numbers for bowl and base come up on the list for 1954-59 Chevy Truck 261 applications. The original tag number is listed in far left hand column for the carb. wink
~ Dan
1951 Chevy 3 window 3100
KEVINSKI #1590976 11/01/2025 2:47 AM
Thanks Dan looks like the carb is for a 261.
"The Journey"
Follow in the DITY
AD Addict & Tinkerer
Some Rochester B carbs (including mine) had the model number stamped on the bottom of the throttle body.
Rochester Carb model number
Phil
Updated to: β€˜59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc Brakes
Project Journals
Stovebolt Gallery Forum
KEVINSKI #1591044 11/01/2025 11:55 PM
Yes 5140 stamped like yours on the bottom .
"The Journey"
Follow in the DITY
KEVINSKI #1591048 11/02/2025 12:37 AM
It is easy to tell a 235 carb from a 261 carb by the venture size but the throttle bore size.
Carb bore.
My Blog
KEVINSKI #1591063 11/02/2025 12:59 PM
Kevin, your identification is correct. Here is a screen print of the Tech Tip in the Engine Forum titled Carburetor Identification--Rochester B Seriesβ€œ
Screen print Identification Rochester B Series
Phil
Project Journals
KEVINSKI #1591077 11/02/2025 3:10 PM
Thanks Phil good to be able to confirm from the numbers as there is no tag. ,Dave I see the bigger Venturi size also as well as the throttle throat size ,I see in your picture of the 235 base it looks to be widened out were the bolts are is that how they were casted .Now would a 261 carb be of any benefit to go on a 235 ?
"The Journey"
Follow in the DITY
KEVINSKI #1591082 11/02/2025 4:05 PM
Insomniac
Insomniac
I have a 261 carb (7015013) on my 235. The #64 jet was replaced with a #57. Probably not much of a benefit...
Gord πŸ‡¨πŸ‡¦
1954 1/2 ton 235 4 speed
KEVINSKI #1591083 11/02/2025 4:16 PM
I think the bolt holes in my picture were reshaped to put this carb on a 216.
My Blog
KEVINSKI #1591089 11/02/2025 6:24 PM
Thanks for all the good info KevinπŸ‘
"The Journey"
Follow in the DITY
