Jon H ("Carbking") from The Carburetor Shop has been kind enough top share with us some tag and casting number data to help with:
1. Identifying a swap meet or parts stash carburetor to see if it will work on your application;
2. Identifying the correct B-Series for your application (helping you know which B-Series carb to look for).
I've broken out Jon's data by Common B-Series (the ones you're most likely to encounter in a parts stash, swap meet or junkyard), Application and Tag Number.
Note -- We do not have complete data on bowl or throttle body casting numbers -- just those associated with the more common tag numbers. So hopefully, if you have a missing tag, the carb in question will be a common one and still be identifiable.
~ John
"We are not now that strength which in old days Moved earth and heaven; that which we are, we are"
1948 International Farmall Super A 1949 Chevrolet 3804 In the Legacy Gallery | In the Gallery Forum 1973 IH 1310 Dump 2001 International/AmTran RE3000 "Skoolie" 2014 Ford E-350 4x4 (Quigley)
