Anyone know the numbers for a 261 carb .I noticed the other day when I was messing with some linkages to try and hook up my carter carb that I have 3 different Rochester carbs .I do know that one came off a 216 as I took it off myself and the bolt pattern is smaller than the one that came off of my 235 the other carb that was a spare to the origional Rochester that came with my truck looks bigger at the bottom and has 5140 stamped on the bottom of the base and 7005606 long the side of the base .The bowl has7005604 .
Unless you happen to have the triangular sheet metal tag that the carb came with originally, held on by one of the top cover screws- - - - -the one that usually got lost during the first rebuild, identifying a Rochester is a crapshoot. Several main body and throttle body casting numbers were used across a wide variety of very differently calibrated carbs. Carb King has posted a pretty comprehensive list of the various tag numbers, but without the tag number, it's a guessing game. Jerry
Those identity numbers for bowl and base come up on the list for 1954-59 Chevy Truck 261 applications. The original tag number is listed in far left hand column for the carb.
~ Dan 1951 Chevy 3 window 3100 Follow this story in the DITY Gallery "My Grandpa Carl's Truck and How it Became Mine" 1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
Some Rochester B carbs (including mine) had the model number stamped on the bottom of the throttle body.
Phil Moderator, The Engine Shop, Interiors and Project Journals
1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: β59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc Brakes Project Journals Stovebolt Gallery Forum
Thanks Phil good to be able to confirm from the numbers as there is no tag. ,Dave I see the bigger Venturi size also as well as the throttle throat size ,I see in your picture of the 235 base it looks to be widened out were the bolts are is that how they were casted .Now would a 261 carb be of any benefit to go on a 235 ?
