2 members (Buckeye998, WICruiser), 125 guests, and 0 robots.
Topics128,101
Posts1,056,172
Members48,436
#1590623 10/28/2025 1:54 PM
I'm going to remove the water pump from my 1940 half ton pickup today. It looks to me like the radiator should come out, in order to have enough space to get to the pump. I should remember, because I built the truck, but that was about 20 years ago, and I don't remember. Working over those huge old front fenders is not easy for an old guy. I just want to make it as easy as possible.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1950 Studebaker Starlight Coupe
1947 Indian Chief
1943 Indian 741
I always remove the radiator. You have to drain the coolant anyway. And then you will have room to work without scraping your knuckles on the radiator or damaging the radiator if a wrench slips.
Thanks, that's what I did. It looked as if it would be very difficult to do, if even possible, with the radiator in place.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1947 Indian Chief
1943 Indian 741
