5 members (frogfarmer, Charles in CA, Joe H, dt235sd, 1 invisible), 61 guests, and 3 robots.
Topics128,074
Posts1,055,910
Members48,429
#158917 02/11/2007 9:12 PM
I guess I an getting oldler than I thought. I went to Harbor Freight to get a clutch head driver so I could start taking the rear fenders off my 57. When I couldn't find one I asked a kid working there if he knew what a clutch head bolt was and of course he had no idea. I went to Sears and found a screwdriver set with about 20 interchangable ends.It had 2 clutch head ends but both were way too small, and I don't want to spend $25 for an entire set anyway. Can anyone tell me where I can buy a clutch head end for my 3/8 impact driver to fit the bed fender bolts?
1957 Chevrolet 1/2-ton Stepside LB in the Gallery
My Photobucket shots
The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873)
#158918 02/11/2007 10:02 PM
check at NAPA or a Mac or SnapOn tools seller
#158919 02/11/2007 10:22 PM
Thanks Bill. I thought about that after I posted this. I checked Mac/Matco & SnapOn on line but didn't pull up anything. I am going to a body shop tomorrow and will take one of the bed bolts in with me. I will see if the local SnapOn or Mac guy still sells them.
#158920 02/11/2007 11:04 PM
i got my set from snap-on but had to order them.
#158921 02/12/2007 8:23 AM
Go to the Snapon site and type "clutch" in the search box. It'll bring up 1/4" and 3/8" drive sockets.
#158922 02/12/2007 8:24 AM
#158923 02/14/2007 4:52 AM
tighten nuts till they break, mine wouldn't come off anyways.
#158924 02/17/2007 1:02 AM
I found a SnapOn dealer in my area who ordered what I need. Only $12.00 too.
I took the old bolts out with a 1/2 inch socket and the always useful Vice grips. Hey Beaver 53, that is exactly how I got most of them off. It was faster that blaster & waiting.
I have the clutch head socket coming so I can put original bolts back in and not mark them up with the Vice grips. Thanks all.
#158925 02/17/2007 4:01 AM
Alans57, around here Home Depot and sometimes Lowes, has them individually. Usually about 4 bucks a piece. Just FYI for those that may still be looking.
#158926 04/07/2007 9:12 PM
I've got the same problem...just started on my '51 and as far as I can tell there are 5 different sizes that were used. The largest is for the fenders and smallest size was on the back of the ignition switch. I ordered a set of 4 screw drivers from Classic Industries today ($19.95) and a Matco Tools Distributor has 3 different sized socket drivers on order for me. I'm going to figure out all of the available sizes etc. and will advise later. Now I need to find out where I can buy extra clutch bolts because I'm sure I'll break a few.
#158927 04/08/2007 5:30 PM
American Classic Truck Parts sells the fender bolts and all the other bolts for the truck too.I have bought several things from them and have been pleased so far. You can go to the news tab and scroll down to their add & click on it to bring up their web page.
#158928 05/22/2007 3:50 AM
I bought a set but most of mine I had to drill out. I HATE CLUTCH HEAD BOLTS! :mad:
#158929 05/22/2007 9:10 AM
got mine at a chevy swapmeet
#158930 05/22/2007 11:33 AM
All the above.
Measure clutch head across diameter.
McMaster Carr sells individual Irwin 1/4” hex drive bits in 3/32”, 1/8”, 5/32”, 3/16”, 1/4” nothing bigger.
The four piece screw driver set that the vendors sell 5/32”, 3/6”, 1/4” and 5/16” are all 1/32” under the nominal size, they fit very sloppy.
Don’t know of any 3/8”sizes that are used on the 1/2 or 3/4 ton trucks so the 5/16” size that Snap On sells would probably be the only one you need from them.
Clutch head bolts, screws; Restoration Specialties & Supply, Inc., P.O. Box 328, Windber, PA 15963, www.restorationspecialties.com
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
#158931 05/22/2007 6:40 PM
A lot of Ace Hardwares have them in stock. Maybe worth a try or you local hardware store.
Dan
Moderated by  MNSmith
