6 members (Donf, tclederman, Shade Baby, TUTS 59, Chip O, Wayne67vert), 80 guests, and 6 robots.
Topics128,188
Posts1,057,218
Members48,465
Apprentice
Apprentice
1 Offline
guys just bought an arc welder from harbor freight ,it can be attached to a 115 or 230 volt plug . my problem is that it has
green and yellow wire ---------------ground
blue wire ---------------------------neutral
brown wire --------------------------hot
black wire---------------------------for 230v only
my cord that i am trying to attach has
white wire
green wire
black wire
i've tried different ways but can't get this thing to run . help i already returned one welder because i thought something was wrong .
for 115, if that's what yer cord is:
grn/ylo to green
blu to white
brown to black
black taped off
but it'd be better to use 230
Your power cord from the panel is 110 Volts,right!?? Blue would be white,green&yellow would be green and brown would be black for 110 volts.
*For 220 volts
Green and yellow = Green
Blue = equipment ground
Brown = 110 volt leg
black = 110 volt leg
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
Apprentice
Apprentice
1 Offline
that's it thanx guys . now i feel bad cause there was nothing wrong with the other .good news they did the exchange with no prob.
1965BADASS........all info given is correct. I also have a dual voltage welder and that is the way I wired mine...
Carl
'58 3600 350/4-sp/stepside/big window cab
'59 3100 235/4-sp/stepside
Moderated by  MNSmith
