| | | Forums66 Topics128,193 Posts1,057,246 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 8 Apprentice | | Apprentice Joined: Oct 2006 Posts: 8 | guys just bought an arc welder from harbor freight ,it can be attached to a 115 or 230 volt plug . my problem is that it has
green and yellow wire ---------------ground blue wire ---------------------------neutral brown wire --------------------------hot black wire---------------------------for 230v only
my cord that i am trying to attach has white wire green wire black wire i've tried different ways but can't get this thing to run . help i already returned one welder because i thought something was wrong . | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | for 115, if that's what yer cord is: grn/ylo to green blu to white brown to black black taped off but it'd be better to use 230
Bill | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Your power cord from the panel is 110 Volts,right!?? Blue would be white,green&yellow would be green and brown would be black for 110 volts. *For 220 volts Green and yellow = Green Blue = equipment ground Brown = 110 volt leg black = 110 volt leg
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Oct 2006 Posts: 8 Apprentice | | Apprentice Joined: Oct 2006 Posts: 8 | that's it thanx guys . now i feel bad cause there was nothing wrong with the other .good news they did the exchange with no prob. | | | | | Joined: Oct 2006 Posts: 125 Member | | Member Joined: Oct 2006 Posts: 125 | 1965BADASS........all info given is correct. I also have a dual voltage welder and that is the way I wired mine...
Carl
'58 3600 350/4-sp/stepside/big window cab '59 3100 235/4-sp/stepside
