5 members (baldeagle, cmayna, GMCJammer51, dt235sd, 1 invisible), 70 guests, and 5 robots.
Topics128,017
Posts1,055,338
Members48,419
#158712 12/27/2006 6:35 PM
I've got an upright Craftsman compressor. I was trying to close the bottom drain and it kept hssing at me. I screwed it all the way in and it kept hissing and then, like an idiot, I screwed it out until it blew out the bottom like a wine cork in a cartoon. Apart from being really loud and kinda neat, did I break my machine? Do I have to deal with a little hiss forever, or is there some fix for my idiocy?
Jason
Your lack of preparation is not my emergency
#158713 12/27/2006 7:05 PM
Nahhhh, it is simply a drain petcock like is used on a radiator. Should be able to pick up a new one @hardware store,or you can use an elbow & a couple nipples & bring the drain out from under the tank where it is easier to mess with. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#158714 12/30/2006 10:14 PM
Put teflon tape or plumers putty on threads reinstall should be OK. like the man said elbow with short nipple and then shut off good idea.
jbennett
40 burb
#158715 12/31/2006 1:23 AM
I thought about the teflon tape, but I drain it every use like the book says to avoid condensation and rust. (sissy). I trid to get an elbow and petcock, but it's a left hand thread. No one locally had it. I just ordered anojther one from Sears. Thanks for the input...
Jason
#158716 12/31/2006 3:23 PM
REPLACE the whole valve, not just the screw in part
#158717 01/01/2007 2:24 AM
I never thought about that either. I'll check local supply houses and see if I can find one.
Jason
#158718 01/01/2007 6:33 PM
I have a ball valve from the local hardware store on mine that has been hanging in there for years.The orignal cheapy P-cock didn't last long at all.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
Moderated by  MNSmith
