0 members (),
35
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 168 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 168 | I've got an upright Craftsman compressor. I was trying to close the bottom drain and it kept hssing at me. I screwed it all the way in and it kept hissing and then, like an idiot, I screwed it out until it blew out the bottom like a wine cork in a cartoon. Apart from being really loud and kinda neat, did I break my machine? Do I have to deal with a little hiss forever, or is there some fix for my idiocy?
Jason
Your lack of preparation is not my emergency
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Nahhhh, it is simply a drain petcock like is used on a radiator. Should be able to pick up a new one @hardware store,or you can use an elbow & a couple nipples & bring the drain out from under the tank where it is easier to mess with. Brian | | | | | Joined: Oct 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 112 | Put teflon tape or plumers putty on threads reinstall should be OK. like the man said elbow with short nipple and then shut off good idea. jbennett 40 burb | | | | | Joined: Sep 2004 Posts: 168 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 168 | I thought about the teflon tape, but I drain it every use like the book says to avoid condensation and rust. (sissy). I trid to get an elbow and petcock, but it's a left hand thread. No one locally had it. I just ordered anojther one from Sears. Thanks for the input...
Jason
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | REPLACE the whole valve, not just the screw in part | | | | | Joined: Sep 2004 Posts: 168 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 168 | I never thought about that either. I'll check local supply houses and see if I can find one.
Jason
| | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | I have a ball valve from the local hardware store on mine that has been hanging in there for years.The orignal cheapy P-cock didn't last long at all.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
