2 members (fonz8261, Oswald),
157
Mod | | | Forums66 Topics128,125 Posts1,056,337 Members48,440 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | I have a portable forced air heater. similar to a reddy heater. It quit while on loan to Brother in law. I took it apart replaced the rotor, cleaned the spark plug. Now it runs while I have the top cover off but cuts off within a minute or so of putting cover back in place. tried adjusting pressure screw but no change. suggestions? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | run it with the cover off? never loan anything to the bro again?  the cover being on is causing something to overheat and there's overheat protection, either for the motor or the burner .... which may be getting weak Bill | | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | On my Reddy Heater, if the filter is plugged up, the unit cuts out. A new filter set solved the problem for me. | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | Thanks for the input. The heater will run for hours with the cover off but shuts down within a few minutes when I slide the cover fully in place. thought about running without cover but don't like the fan blades being exposed if some one else is around or the heated funnel either. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Same thing happend to me. I could run the thing with a 1/2 in crack between the body and cover. I changed the filter, no help. Of all darn things I put new kerosene in it and it fired right up. Can't explain that but the fuel was about 1 yr old. | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | ok I'll try draining it. the other heater runs on the fuel but this one had been seting longer. since i didn't need it right away | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | I'm with Bill...hidden in there somewhere is a thermal switch that is telling the unit it is too hot and needs to shut down. Although they don't cycle much, these switches can go bad. If it isn't a bad switch, then maybe something is blocked/plugged that is allowing hot air to enter that covered space and overtemp the heater when the cover is installed.
As my son always says..did you Google it dad?
Stuart | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Don't know why but mine started working fine now. | | | | | Joined: Jan 2007 Posts: 38 Apprentice | | Apprentice Joined: Jan 2007 Posts: 38 | There is a air pump, or blower to atomize the kerosene to make a fuel air mixture to burn. sometimes the air pump orifice becomes plugged and needs to be cleaned out with compressed air. This usually will fix the problem. Had same problem before. Not enough atomization and will only burn when not as much air blowing over it. Thus the flame goes out when you have all of the air concentrated with the cover on. | | | | | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | Get new plug.Plug insullators become saturated and allow conductivity to ground. | | | | | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | Another thought.The orface may have picked up some trash and not atomizing correctly.These can be taken out and cleaned, Has two hoses to it keep up whith where each goes. One is air other is suction. | | |
