| | | Forums66 Topics128,142 Posts1,056,485 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2021 Posts: 258 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 258 | 1949 - 1954 216 or 235 engine oil pressure: Question: Once you reconnect the oil pressure line, do you have to bleed the oil line that goes from the engine to the indicator? | | | | | Joined: Feb 2004 Posts: 29,819 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,819 | No need-- - - -if a few bubbles are in the line, they will compress and give a correct pressure reading. Don't be surprised if a 216 has little to no oil pressure at hot idle. Spray-oil engines can run with 15 PSI or less oil pressure at hot idle, and even less is not uncommon. 235 full pressure engines will have quite a bit more, but one with a lot of miles and some rod bearing wear will also be lower on pressure than most people are comfortable seeing. Jerry
| | | | | Joined: Oct 2021 Posts: 6,842 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,842 | My 216 runs at 7-8 psi at hot idle and 15 psi on the road.
It will run briefly at 15+ psi at cold startup.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Mar 2021 Posts: 258 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 258 | Otto, thanks for the pressure information. Those pressures are about what we've experienced. This 216 engine also had a disconnected low oil pressure switch and light. I have just rewired in the light. | | | | | Joined: Oct 2021 Posts: 6,842 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,842 | Texas, do you have a shop manual for your truck?
Those are the pressures listed in the manual for a properly functioning engine so as long as my engine (and yours) operates withing those ranges, I don't worry about it.
People used to modern vehicles with 30-80 psi get nervous with such low pressures but it's perfectly normal for these engines.
| | | | | Joined: Mar 2021 Posts: 258 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 258 | Yep. I have a manual. Yes I too have had doubts about the oil pressure as many others have had. | | |
