7 members (3B, Bill Hanlon, TooMany2count, Otto Skorzeny, Peggy M, GDW, 1 invisible), 114 guests, and 2 robots.
Topics128,139
Posts1,056,460
Members48,441
1949 - 1954 216 or 235 engine oil pressure:
Question: Once you reconnect the oil pressure line, do you have to bleed the oil line that goes from the engine to the indicator?
No need-- - - -if a few bubbles are in the line, they will compress and give a correct pressure reading. Don't be surprised if a 216 has little to no oil pressure at hot idle. Spray-oil engines can run with 15 PSI or less oil pressure at hot idle, and even less is not uncommon. 235 full pressure engines will have quite a bit more, but one with a lot of miles and some rod bearing wear will also be lower on pressure than most people are comfortable seeing.
O Online: Content
My 216 runs at 7-8 psi at hot idle and 15 psi on the road.
It will run briefly at 15+ psi at cold startup.
1950 Chevrolet 3100 (Ol' Roy)
Otto, thanks for the pressure information. Those pressures are about what we've experienced.
This 216 engine also had a disconnected low oil pressure switch and light. I have just rewired in the light.
O Online: Content
Texas, do you have a shop manual for your truck?
Those are the pressures listed in the manual for a properly functioning engine so as long as my engine (and yours) operates withing those ranges, I don't worry about it.
People used to modern vehicles with 30-80 psi get nervous with such low pressures but it's perfectly normal for these engines.
Yep. I have a manual. Yes I too have had doubts about the oil pressure as many others have had.
