1 members (RLB), 81 guests, and 1 robot.
Topics128,162
Posts1,056,940
Members48,458
Hello Stovebolt family! Took a year off to remediate my flooded basement, but I'm back now.
Does anyone have, or can you point me to, diagrams that show how to attach the tongue bracket to the windshield frame?
I have a box with some parts, and want to make sure I have everything to get my Jim Carter Truck Parts regulator back in operation. Thanks in advance!
My ‘46 GMC. My apologies for the Philip head screws.
Other than blowing lots of engine heat right into the cab, (and leaking in a rainstorm) what purpose does a windshield like that serve?
It’s better AC than you might think.
The ‘46 Chevy 1/2 ton uses the same somewhat “T” shaped bracket posted by greenie-reddy.
True. Especially with door windows down and some speed while cruising down the road. Floor board insulation also helps.
Plus you get bug splatter on you with it open!
HRL, I have three trucks with crank open windshields, '37 & '42 chevrolets and my '47 Diamond T. The Diamond T has a split windshield with two separate cranks. I call that "zonal climate control".
Since my trucks are stock, there is no better feeling than driving down the highway (at 45 mph) with the windshield cranked open on a warm summer day. The design does not pull in engine heat, rather fresh air over the top of the hood.
Regarding rain, I live in Arizona, so that is not much of a problem. I am sure rain is the chief reason designers abandoned the concept by 1950. There is an interesting difference between the '37 and '42 and that is the presence of corner drains along the window bottom of the '42. These drains connect with rubber hoses that go out the bottom of the truck behind the kick panels. Kind of a hokey arrangement.
Design is often an evolution and the drivers of these trucks cut their teeth on trucks with open cabs that might even have a roof if you were lucky. Crank open windshields probably seemed like quite an advancement. Today, I enjoy the "charm" of designs.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
How about: it came that way and I’d like it to function?
I actually use mine open more than one might think, around town often, and on the freeway at 70 degree outdoor or above heck yes….
And yes… windshield leak is a given….
Chuck
Hank: 46 Chev 1/2ton shortbed
2023 Miata RF Club
Thank you all for the lively discussion (and the very helpful photo!)
I'm totally with "Hank's custodian" on the crankout windshield: 1946 was the last year Chevrolet made it operable. When I inherited Rosie, the windshield was sealed closed with seemingly bucket-loads of caulk. I determined then that I wanted it to work again in celebration of it's history. Besides, I think it's a quirky-cool feature on a quirky-cool truck!
I'm not too worried about rain infiltration since I would be disinclined to drive it in those conditions anyway (I already have bed boards that need to be refinished...)
If my truck were of that vintage I would definitely want that feature to function.
The tilt open windshield realllyyy dates the truck. I bet there were many a farmer in places like Texas and Oklahoma that were very happy to have that airflow available on a smokin’ hot day.
