5 members (Hotrod Lincoln, Chip O, greenie-reddy, rfs56trk, ole green), 89 guests, and 10 robots.
Topics128,077
Posts1,056,013
Members48,433
#1585441 08/19/2025 2:14 PM
Ladies and Gents,
I’m converting a stock ‘51 Chevy 3100 to an open driveline. I have the 3speed with Od and proper ‘61 carrier that will bolt in.
If I were to rebuild the axle while I have it apart, what do I need? I’m not worried about axle perch or driveshaft, etc.
I’m tracking the following axle parts:
Center pin for spider gears (recommended by Tut)
Gaskets (for pan and carrier)
Gear oil
Seals? (Not sure how many or which ones)
I appreciate any help on this. I’m starting the project in OCT and diving farther into my research and planning.
Chris
E Online: Content
When I put the T5 in mine in 2019, I used this USA Standard Gear kit (I don't remember it being listed as for car and truck at the time, just truck).
I think it's the same as this Yukon Gear kit, but with different brand bearings.
I got mine on Amazon, or from Summit or Jeg's, can't remember. Shop around for price. Amazon $108 !
Had the diff rebuilt at a shop, and we installed the wheel bearings and seals and put the diff in the axle housing. IIRC, no gasket for the cover, just Permatex.
Crusty Old Sarge
Crusty Old Sarge
T Online: Content
According to Yukon Gear this is the Center link Pin you need. They also list a gasket and seal kit. Search 1962 Chevrolet C10, 235.
https://www.yukongear.com/shop/yspxp-038
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Thanks guys! I’m making sure I have everything so I can start working on Oct 1st! I can also do the Bel Air this winter (changing the running gear to 3.55)
Chris
