3 members (Southerntruck, KEVINSKI, TPR57C), 176 guests, and 2 robots.
Topics128,114
Posts1,056,287
Members48,439
#1585441 08/19/2025 2:14 PM
Ladies and Gents,
I’m converting a stock ‘51 Chevy 3100 to an open driveline. I have the 3speed with Od and proper ‘61 carrier that will bolt in.
If I were to rebuild the axle while I have it apart, what do I need? I’m not worried about axle perch or driveshaft, etc.
I’m tracking the following axle parts:
Center pin for spider gears (recommended by Tut)
Gaskets (for pan and carrier)
Gear oil
Seals? (Not sure how many or which ones)
I appreciate any help on this. I’m starting the project in OCT and diving farther into my research and planning.
Chris
When I put the T5 in mine in 2019, I used this USA Standard Gear kit (I don't remember it being listed as for car and truck at the time, just truck).
I think it's the same as this Yukon Gear kit, but with different brand bearings.
I got mine on Amazon, or from Summit or Jeg's, can't remember. Shop around for price. Amazon $108 !
Had the diff rebuilt at a shop, and we installed the wheel bearings and seals and put the diff in the axle housing. IIRC, no gasket for the cover, just Permatex.
Crusty Old Sarge
Crusty Old Sarge
According to Yukon Gear this is the Center link Pin you need. They also list a gasket and seal kit. Search 1962 Chevrolet C10, 235.
https://www.yukongear.com/shop/yspxp-038
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Thanks guys! I’m making sure I have everything so I can start working on Oct 1st! I can also do the Bel Air this winter (changing the running gear to 3.55)
Chris
