| | | Forums66 Topics128,111 Posts1,056,244 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 2,234 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,234 | Ladies and Gents,
I’m converting a stock ‘51 Chevy 3100 to an open driveline. I have the 3speed with Od and proper ‘61 carrier that will bolt in.
If I were to rebuild the axle while I have it apart, what do I need? I’m not worried about axle perch or driveshaft, etc.
I’m tracking the following axle parts: Center pin for spider gears (recommended by Tut) Gaskets (for pan and carrier) Gear oil Seals? (Not sure how many or which ones)
I appreciate any help on this. I’m starting the project in OCT and diving farther into my research and planning.
Chris | | | | | Joined: Jul 2014 Posts: 362 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 362 | When I put the T5 in mine in 2019, I used this USA Standard Gear kit (I don't remember it being listed as for car and truck at the time, just truck). I think it's the same as this Yukon Gear kit, but with different brand bearings. I got mine on Amazon, or from Summit or Jeg's, can't remember. Shop around for price. Amazon $108 !Had the diff rebuilt at a shop, and we installed the wheel bearings and seals and put the diff in the axle housing. IIRC, no gasket for the cover, just Permatex.
| | | | | Joined: Mar 2007 Posts: 3,397 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,397 | According to Yukon Gear this is the Center link Pin you need. They also list a gasket and seal kit. Search 1962 Chevrolet C10, 235. https://www.yukongear.com/shop/yspxp-038
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Jan 2013 Posts: 2,234 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,234 | Thanks guys! I’m making sure I have everything so I can start working on Oct 1st! I can also do the Bel Air this winter (changing the running gear to 3.55)
Chris
