2 members (FAST55, 1 invisible),
69
Mod | | | Forums66 Topics128,154 Posts1,056,838 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | 1965 Chevrolet C10 long bed step side pickup
starter intermittent
original wiring harness with various previous owner strangeness repaired over the years and at least two semi meltdowns I have repaired since I have owned it.
The issue:
Sometimes I hit the starter and it turns right over. Other times it goes to start, makes a slight sound and then, nothing.
Things I have checked or done.
replaced starter solenoid, but it was chattering... took the starter to an actual rebuild shop(didn't know any where still around, yay) and had them fix it/check it over.
I bought another ignition switch, switched over the lock, plugged it in, sometimes, same deal. So, maybe I have two wonky ignition switches, or it is something else. Put the other switch back in.
Oh yes, I also wired up a momentary switch to the starter itself, so when this intermittent thing happens and it had no start, I hit the momentary switch and it turns right over. So, I don't think it is the starter itself.
I checked continuity from the plug on the back of the ignition switch, the purple wire to the firewall inside the cab. Then from the plug on the inside the engine compartment down to the starter(one of the newest parts of the wiring harness) and it is still good. Used a digital multi-meter to check continuity on the OHMs setting.
Could be some losing contact in the firewall plug maybe? Hmnn. No idea how to check that though.
So, I am leaning towards maybe a short on the side of the harness coming to the plug... or in the engine compartment coming to the firewall/fuse block.
Anyway, that is where I am now.
If anyone has any weird suggestion of things to check, try or troubleshoot, please let me know.
Thanks.
-Woogeroo | | | | | Joined: May 2015 Posts: 11,131 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,131 | Try cleaning the battery terminals, as well as the large gauge cable connections at the starter and ground. I'll bet you'll find a loose or corroded connection. The solenoid chattering is the clue that it doesn't have enough voltage to stay pulled in.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | "Oh yes, I also wired up a momentary switch to the starter itself,"
Please explain exactly how this is wired. Where is the momentary switch located?
Also, do you turn the key switch to "ON" and then use the momentary?
I will suggest troubleshooting after I see these answers.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Try cleaning the battery terminals, as well as the large gauge cable connections at the starter and ground. I'll bet you'll find a loose or corroded connection. The solenoid chattering is the clue that it doesn't have enough voltage to stay pulled in. Already did the wiring cleaning thing on each end of both main battery cables and the small wire on the starter side with electrical cleaner and wire brushes. Finished it up with a thin bit of die electric grease. The starter was rebuilt/repaired by a starter shop and they replaced the solenoid as well. Apparently the new one I put on was junk(less than a month old), thanks NAPA. | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 |
