3 members (WICruiser, 2 invisible),
142
Mod | | | Forums66 Topics128,109 Posts1,056,269 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | I was just thumbing through the fall 2006 Northern Tool&Equipment catalog. On page 119 in the pressure washer section they sell two sand blasting kits that work with a pressure washer  one is $62.99 the other is $109.99  . Have any of you used one of these? Do they work? How about with soada as a blasting agent? Any way what do you think? I have a 4gpm 3500psi washer should I try it? :rolleyes: I need to blast my dump box. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | HevyHauler,
I took a look at the $62.99 kit. It sure solves the problem of having only a small air compressor. The combination of abrasive and high pressure water would seem to be a winner for a nasty old dump box.
My only question would be how to address freshly blasted, clean steel being bathed in water.
It would instantly flash with surface rust. I guess a rust inhibiting primer might deal with it, but when I blast with the conventional air/sand combination, I do everything in my power to keep the bright metal shiny until I get some protection on it.
I wonder if the Northern Tool setup is designed for something other than steel...maybe a concrete structure or sidewalk.
Stuart | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | After your done blasting spray it with some metal etch. I've used both Jascos' Metal Etch and Rustmort. Rustmort seems to be a little better, but the only place I've been able to find it is at an auto paint supplier. Jascos' Metal Etch works good and you can get it at Ace, OSH. It's a little cheaper than Rustmort too. Both are essentially phosphoric acid. Either will kill the flash no problem.
Larry
I don't own a vehicle that isn't old enough to drink. | | |
