Brrrr
Winter is Coming
Stored trucks should have a high-quality security system. A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Jon G, Dennys28, Uncles51, texas46), 113 guests, and 1 robot.
Topics128,279
Posts1,058,593
Members48,492
#1583656 07/27/2025 10:17 PM
Hello, I am getting ready to replace my master cylinder and would like to bleed the system at the same time. There has been a popup lately showing a hose with a check valve that keeps the vacuum from letting in air. Would be good for a one man job. Anyone else seen this or used one? They are cheap on line, but a lot of the cheap vacuum bleeders got bad reviews here. Any thoughts?
Former Workshop Owner
J Online: Content
I gravity bled the last time on my ‘69 1 1/2 ton. It wasn’t fast but it worked.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
That was my plan but thought this may help. nice 59. Hope mine will look as good when Im done.
More than a few of us use a Motive pressure bleeder, it just works, quick and easy once you figure out how to fit on the master you have…., 10 psi of fluid pushed into the master and it is a matter of opening the bleeders one at a time…..
Many adapters to choose from for your master cylinder, I have a dual master in my 46 so I use the universal…..I use clamps instead of provided chains….
Summitracing search motive bleeder
Chuck
Hank: 46 Chev 1/2ton shortbed
2023 Miata RF Club
Saw that nice product . I was trying to figure out how to make something like that. would do the job.
B Online: Content
Originally Posted by Hanks custodian
I use clamps instead of provided chains…. Chuck
What kind of clamps? Fairly small C clamps?
6” C clamps work on my master cylinder, they just fit…
Chuck
2023 Miata RF Club
Why not just use speed bleeders? They have a built-in check valve. Loosen the bleeder screw 1/4 turn and slowly pump the brake pedal up and down.
I just ordered a set of those bleeders. They arrived last night. I have not used them yet but might this weekend. If I do, I will report back.
Mike
24601
24601
I have one of those Motive Power pressure bleeders. But I saw somewhere (might have been here...) about someone making their own pressure bleeder out of a hand held insecticide/herbicide sprayer ... I guess you could use a extra M/C cover and add a port to it from the sprayer, pump it up to 10 psi and Robert's your mother's brother.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Moderated by  MNSmith
