7 members (MickeyP, RoadsScholar, Gdads51, 1955 1 Series, thekid1950, tclederman, klhansen),
117
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,068 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 14 'Bolter | | 'Bolter Joined: Jul 2010 Posts: 14 | The lower front on the hood of my 65 is pretty rotten. I know I can buy a new panel but I am not sure how to change it. I can see the spot welds on the bottom but I can't see what holds the upper part. Can anyone here offer a little advice? Thanks | | | | | Joined: Sep 2009 Posts: 5,864 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,864 | I couldn't find ant detailed help on your topic when searching through the Stovebolt archives. I did find this 2013 on-topic thread at Classicparts.com. I think the info and pictures in there will help you answer the question on separating the lower front from the upper part.  Let us know how it turns out.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Jul 2010 Posts: 14 'Bolter | | 'Bolter Joined: Jul 2010 Posts: 14 | Thank you very much, that helps a lot. | | | | | Joined: Sep 2009 Posts: 5,864 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,864 | Good deal!  Perhaps you would post on how yours works out so other Bolters may be able to refer to it in the future.  Any do's and don'ts tips, plus pictures may make it easier for others looking to do the same work.
