4 members (ndkid275, Wally / Montana, Hanks custodian, dt235sd), 88 guests, and 1 robot.
Topics128,131
Posts1,056,723
Members48,454
#1581266 06/30/2025 12:58 PM
Here is my 1940 LRDG truck.
1942 Ford GPW
1943 Ford GPW
T33 jet
MD500 Little bird Helicopter
1940 LRDG WA truck
1940 LRDG WB truck
1.5 ton axle being swapped in
1942 Ford GPW
1943 Ford GPW
T33 jet
1940 LRDG WA truck
1940 LRDG WB truck
Just bought a set of tires to put under it.
1942 Ford GPW
1943 Ford GPW
T33 jet
1940 LRDG WA truck
1940 LRDG WB truck
O Online: Content
Long Range Desert Group? You mean like Rat Patrol?
1950 Chevrolet 3100 (Ol' Roy)
I think you are going to miss the 2-speed rear axle after the swap. Do you know that the ratios are for the 2-speed version coming out and the one going in?
1949/50 3600 Project
Follow in Project Journals
O Online: Content
The tires on that dually rear end are hilarious. A couple of them look 70 years old.
WICruiser #1581413 07/01/2025 11:30 PM
I'm doing a truck that the LRDG would have had in early 1940. That would be a 1.5 ton truck.
1942 Ford GPW
1943 Ford GPW
T33 jet
1940 LRDG WA truck
1940 LRDG WB truck
They are!!
No I mean LRDG formed in 1940.
1942 Ford GPW
1943 Ford GPW
T33 jet
1940 LRDG WA truck
1940 LRDG WB truck
Why are you swapping out the two speed, is it busted? That extra 'slower' range provides a lot of versatility. Cool truck either way though. And regarding the tires.. Perfectly Good!!! :-D
H Online: Content
Interesting- - - - -that's only the second manual shift 2 speed I've seen since the late 1970s!
Look everyone. I'm building a truck as close to the original one used by the LRDG in 1940 for the North African Desert. All the ones I have seen have had the 1.5 ton axle on them. Therefore that is what I'm using. If you are interested in the 2 speed axle it is up for sale. Here are some pictures of the 40 and 41 chevys.
1942 Ford GPW
1943 Ford GPW
T33 jet
1940 LRDG WA truck
1940 LRDG WB truck
Looks like an interesting project! Keep us posted on your progress. It will be fun to see it when it's finished.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
