| | | Forums66 Topics128,012 Posts1,055,320 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | I broke off a 1/4-20 tap in my engine while I was in the process of rebuilding it. I tried many different ways of removing the broken tap and all of my attempts up till now have not been succesful. My brother-in-law said he had heard about a so called "tap extractor," so I did an internet search and low and behold I found such a beast. The tool is made by Walton Company in West Hartford CT and it worked great! I bought the tool from the Toolsource.com for ~ $11. It has 3-4 fingers (depending on the tap you are extracting) and is sized for the tap you need to extract. The fingers are inserted into the flutes of the broken tap and then an integral collar is slid down to surface of the hole to support the fingers and then you use a tap wrench to work the tap free. Just a heads up in case you find yourself with a broken tap in the future.
Jim
1954 GMC 1/2-ton Longbed 1971 Pontiac LeMans Sport
| | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | Very handy!! Yep! Those taps have a way of breaking when you least want them to! | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Then how do you extract a broken tap extractor? If they make it I can break it! | | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | EDM or take a realy good punch and chip it out. The tap is real brittle and will come out in little chuncks. The EDM is a electric discharge machine that will burn the tap and what ever else is in the hole out and leave the threads intact. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You could always weld a nut on the end of it, of course you ca get the tap out that way too.
Bill Burmeister | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Then how do you extract a broken tap extractor? The tap extractor has three or four fingers, as described in the initial post, which slide down into the flutes of the broken tap. It is highly doubtful you could break the fingers off but if you did a magnet will suck them right out of the hole. They would most likely bend rather than break if your tap is in that tight. If it is that tight you have problems a tap extractor won't solve. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | While I'm here, how about a tip or two to reduce the chance of a broken tap? If you are a trained machinist or mechanic you should already know this. But there are a lot of people on this site working their first mechanical project.
1. Use a tap lube. Tap-eze is a very good one for steel.
2. Use a tap handle. Don't try to get by with Vise-grips. The straighter you can hold the tap, the less chance for breakage.
3. If you are cutting new threads, back off the tap to break the chips after each revolution. After 4-5 revolutions, back the tap out and blow or wipe it off. Blow the chips out of the hole if you have air or use a Q-tip. Squirt some more Tap-eze in there.
4. If you are using it as a "thread brush" on old threads you won't have the build-up of chips but it's still important to use lube and to back off occasionally.
5. If you are cleaning up threads in an area where chips could cause harm, as in an engine block, pack the flutes with axle grease to catch the chips. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | My metal shop instructor in high school always told us 1/2 turn in, then 1 turn back out. Repeat.
Over the years I have found that when I spent more money on good machinist taps, I had less problems with breaking because they cut so much better. | | |
