7 members (TexasJim50, DadsFirstPickup, 54farmtruck, Patharr, klhansen, Pete1946, 1955 1 Series), 114 guests, and 4 robots.
Topics128,148
Posts1,056,811
Members48,454
#1579591 06/11/2025 1:07 AM
I’m wanting to get everything welded up before I get too serious about pounding and fine tuning these fenders. As you can see from the picture the frame opening is pretty beat out to missing. It appears it rolled in about 2 1/2” from the edge of where it attached to the dog house. Lower left. Anyone have a ‘37-38 that would be willing to draw out a template with measurements that would make sense to fabricate from that corner that is still intact? The passenger side is worse. There is also a light duty angle iron welded across the top. Is that original or a bad attempt at a repair? Help!! lol
Larry
Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY.
If you are missing one component, you'll need an abundance of the others two.
I dont have dimensions or a template as my truck is currently torn down, but I found these pictures from a 38 fender I have in storage. I believe they are the same, hope it helps.
Mine are fiberglass, but look just like the photos, I can measure them if you want.
Same for my fiberglass fenders too.
Mike, maybe a measurement of the depth of the opening from the plane of the bottom of the fender would be body helpful. Alvin, I’d appreciate a closeup of the clearance where the frame horn comes out through here. Thanks guys and help out with my next issue posted.
Larry
