| | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | Visit the link, see if you can guess what these items are, post your answers here! http://puzzlephotos.blogspot.com/ Answers are typically posted in a few days. The first to answer all correctly or gets the most correct here at the Stovebolt will, at the very least, get a hardy congratulations ( a minimum of 3 out of the six to qualify for a win.) If all goes smooth and we have some decent participation, we'll try to get a small prize to the winner!! Good Luck!! (Rob, the creator of the contest, has final say on what is correct.) | | | | | Joined: Apr 2004 Posts: 158 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 158 | #630 is a microphone.
#631 is a key.
#632 is a tool for seating IC chips.
#633 is a scribe.
#634 no idea.
#635 no idea. | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | Originally posted by Brian McGee:
#631 is a key.
Ah yes, but what kind?? | | | | | Joined: Apr 2004 Posts: 158 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 158 | | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | That had me laughing! Gonna need it's purpose, tho'. | | | | | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | #630 Old Microphone #631 Key (but don't know it's use) #632 IC Chip remover/Installer #633 Veneer Cutter #634 No clue #635 Sheet metal thickness guage
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | ...at the very least, get a hardy congratulations ( a minimum of 3 out of the six to qualify for a win.) I got 3 out of 6 on the last one and didn't even get noticed. Do I need to join a club or fill out and entry form? | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | Hi Cletis,
I counted two on the last one. 625 and 629. Which three are you claiming?? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | Well, your answer and the official answer are both kind of general. I'll give it to you. I'll unlock the post and give you a proper, hardy congratulations there. Of course, that means you'll have to sit out this contest and the next one. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: Feb 2006 Posts: 20 Junior Member | | Junior Member Joined: Feb 2006 Posts: 20 | 1. dispatchers microphone 2. watchmans key. used in conjunction woth a timer, the key is inserted and turned, the number is then stamped on the timer's paper strip. This one would show the watchman was at post #3 when used. 3. IC chip tool 4. Looks like a cheese blocker but the blade is rather short. 5. no idea 6. sheet metal gauge
Allan S Langley B.C Canada
| | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | Answers as per the creator, Rob:
"All but one have been identified this week:
630. Carbon ring microphone
631. Night watchman's key
632. Integrated circuit insertion tool
633. Haven't been able to find out exactly what this is for, I'll have to do more research on this tool.
634. Lightning rod tip
635. Wrest saw set
Links, new photos and more info have been posted on the answer page:
http://pzphotosan111lr.blogspot.com/"
All our participants got three right, #630, #631 and #632. However, Allen (Capt. Al) gave the correct description of the purpose of the key. So, A HARDY CONGRATULATIONS TO ALLEN!!!!!! Well done!!
So, Capt. Al and Cletis get to sit out the next one. | | |
