5 members (HandyAndy, klhansen, Hanks custodian, Hugh63c10, dt235sd), 78 guests, and 1 robot.
Topics128,092
Posts1,056,043
Members48,433
#157929 04/06/2006 7:07 PM
Visit the link, see if you can guess what these items are, post your answers here!
http://puzzlephotos.blogspot.com/
Answers are typically posted in a few days.
The first to answer all correctly or gets the most correct here at the Stovebolt will, at the very least, get a hardy congratulations ( a minimum of 3 out of the six to qualify for a win.) If all goes smooth and we have some decent participation, we'll try to get a small prize to the winner!! Good Luck!! (Rob, the creator of the contest, has final say on what is correct.)
#157930 04/06/2006 7:56 PM
#630 is a microphone.
#631 is a key.
#632 is a tool for seating IC chips.
#633 is a scribe.
#634 no idea.
#635 no idea.
#157931 04/06/2006 8:20 PM
Quote
Originally posted by Brian McGee:
#631 is a key.
Ah yes, but what kind??
#157932 04/06/2006 8:49 PM
Brass.
#157933 04/06/2006 9:13 PM
That had me laughing! Gonna need it's purpose, tho'.
#157934 04/06/2006 10:10 PM
#630 Old Microphone
#631 Key (but don't know it's use)
#632 IC Chip remover/Installer
#633 Veneer Cutter
#634 No clue
#635 Sheet metal thickness guage
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
#157935 04/07/2006 3:37 AM
Quote
...at the very least, get a hardy congratulations ( a minimum of 3 out of the six to qualify for a win.)
I got 3 out of 6 on the last one and didn't even get noticed. Do I need to join a club or fill out and entry form?
#157936 04/07/2006 10:07 AM
Hi Cletis,
I counted two on the last one. 625 and 629. Which three are you claiming??
#157937 04/07/2006 11:10 PM
624 also.
#157938 04/08/2006 2:30 AM
Well, your answer and the official answer are both kind of general. I'll give it to you. I'll unlock the post and give you a proper, hardy congratulations there. Of course, that means you'll have to sit out this contest and the next one.
#157939 04/08/2006 5:03 AM
#157940 04/08/2006 6:44 AM
Junior Member
Junior Member
1. dispatchers microphone
2. watchmans key. used in conjunction woth a timer, the key is inserted and turned, the number is then stamped on the timer's paper strip. This one would show the watchman was at post #3 when used.
3. IC chip tool
4. Looks like a cheese blocker but the blade is rather short.
5. no idea
6. sheet metal gauge
Allan S Langley B.C Canada
#157941 04/11/2006 9:23 AM
Answers as per the creator, Rob:
"All but one have been identified this week:
630. Carbon ring microphone
631. Night watchman's key
632. Integrated circuit insertion tool
633. Haven't been able to find out exactly what this is for, I'll have to
do more research on this tool.
634. Lightning rod tip
635. Wrest saw set
Links, new photos and more info have been posted on the answer page:
http://pzphotosan111lr.blogspot.com/"
All our participants got three right, #630, #631 and #632. However, Allen (Capt. Al) gave the correct description of the purpose of the key. So, A HARDY CONGRATULATIONS TO ALLEN!!!!!! Well done!!
So, Capt. Al and Cletis get to sit out the next one.
Moderated by  MNSmith
