2 members (Bill Hanlon, Stovebolt48), 67 guests, and 2 robots.
Topics128,036
Posts1,055,458
Members48,422
#1578062 05/24/2025 8:51 PM
Hello I need some guidence on a carb for my 59 235 motor Tried to start it this aftn and not good . opened the carb and it has dried out and the potmetal is all frosty. Lookes on line and a few places have new carbs for around $140. a rebuilt from classic is 240 . are these new carbs any good ? i figure they come from off shore. dont know if mine will take another rebuild. Thanks and have a nice weekend
H Online: Content
They're offshore knockoffs that sorta-kinda resemble the original carbs. They'll make most engines run, but not even close to correctly, compared to an original equipment carb. Unless the castings have big holes rotted into them, that cruddy OEM carb can probably be rebuilt to perform much better than a new "clone" that looks better than it runs.
Moderator, Electrical Bay
Hi there. As Jerry said the offshore models are nothing to crow about...actually I would say you should avoid them. Please tell us what kind of carburetor you have. For the year 235 you have the Carter YF3211S is an excellent carburetor.
~ Jon
Jon G #1578072 05/24/2025 10:14 PM
Where could I find the model # ?
That all depends on which carburetor you have??? Please post some pictures of yours and we can better try and help answer your question. wink
If you need help with posting pics, look at this Helpful Thread. I find the easiest method is to watch klhansen's video. It's about the quickest and easiest method I've found to help you get things posted. smile
~ Dan
1951 Chevy 3 window 3100
Looked at it has rochester cast in the top. found a box in the shop with what was left from the last rebuild. had a nice picture of carb. think I will order a kit and see what happens. can always look for a rebuilt on line if that fails Thanks
O Online: Content
I won't hesitate to tell you NOT to buy a new knockoff carb.
I did that before I knew any better (for a Ford inline six) and it is a piece of junk. I would have rebuilt the original crusty one had I known.
Don't just buy a generic kit for your carb. Make sure its the right carb for your engine and then get the exact kit for your carb from carbking at The Carburetor Shop.
1950 Chevrolet 3100 (Ol' Roy)
Very good advice about the kit. Also...could be important to know...for most people it usually is...At the top of the engine section is a Tech Tip about common problems with the Rochester B models. There are two parts and one explains how to solve the problem of warped airhorn and float bowl (very common with Rochester B models and can keep yours from working properly. Hope it helps. Please let us know if you can't find it.
~ Jon
just a quick update. got a kit cleaned the carb and was putting it back when had a problem with float assy, ... see new post. Thanks for the carb king link.
Carburetion specialist
It is important to consider the off-shore knock-off "carburetors".............................
IF you have a rabbit problem in your garden and a strong right arm wink
They may also be used as door stops, paper weights, or if you are a fisherman they may be used to anchor a "trot line". wink
Jon
The Carburetor Shop
