1 members (Bucker), 144 guests, and 2 robots.
Topics128,196
Posts1,057,391
Members48,471
Morning fellow 'Bolters,
I'm coming up empty on my search to find anyone in my region that will re-line shoes and even turn large brake drums. Do any of you have resources that you would be willing to share? The region i'm looking in is NE/SE Kansas, NW/SW Missouri, NE Oklahoma and SE Nebraska.
1951 GMC 451
1964 International Harvester v190
For turning brake drums, pretty much any industrial machine shop with a large lathe will be able to do it. Try asking some oilfield guys if they know of anyone.
1959 Canadian GMC 9600 with a dump box
Intro / Details in Big Bolts
Check with your local Big Rig repair shop, they should have a source for brake shoe linings and drum turning. Local car repair garages aren't setup for big truck stuff.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
I'll be on vacation for Christmas. I'll reach out to some at that time. Thanks
1951 GMC 451
Are your brake linings bonded or riveted to the shoes? I have a shoe riveting machine if you can find the proper linings. There are usually lots of them on Ebay, and the right rivets, at very reasonable prices. On some of the really big rigs (18 wheeler size) the brake blocks are simply bolted to the shoes with pan head screws, with self-locking nuts on the back side. A commercial machine shop with a big lathe and a tool post grinder should be able to clean up your drums.
I used to turn drums, but we quit doing that a long time ago. I still have the machine. If you have someone turn them, make sure they finish with a grinder. The cutter will hop over hot spots and leave you with an out of round drum. I always finished the job with a grinder to grind the hot spots. If you can't find pads, call San Antonio Brake and Clutch in San Antonio, TX. They go out of their way with obsolete stuff. And UPS shipping on just the pads wouldn't be that bad. And you can either rivet or bolt them on.
1 Offline
You might try Lincoln Clutch and Brake Supply, in Lincoln, NE
WW2Chevy
1942 Chevrolet G506 1-1/2 ton 4x4 Army Cargo w/ winch
(Retro-roco)
I got mine relined at Brake and Clutch Supply in Seattle, WA. They are really knowledgeable on the old stuff and have vintage linings in stock.
Former Workshop Owner
Try this shop Auto Brake and Clutch in Omaha. You can tell them they were recommended by John at Arnold Tool in Council Bluffs.
I believe the owners name is Lon.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
All that's really needed to reline brake shoes is a drill press, a few small C-clamps, and a pop rivet gun. Maybe a disc sander to radius grind the lining once it's on the shoes. More sophisticated equipment just makes a high volume shop more profitable.
Would regular (I assume steel) pop rivets hold up to the heat and not fatigue loose?
I had a local tractor repair shop reline mine. If there's one in your area, they might be able to do it.
1947 First Series Chevy 2 ton COE
2005 - It started in the Gallery
2023 - Follow the restoration in my Project Journal
1962 IH Scout 80
1982 Chevy Caprice Classic
The correct rivets are usually brass or steel, but not pop rivets. I don't know that I would trust pop rivets for this, however I could be wrong and maybe they're fine.
A steel, or stainless steel pop rivet will have much greater shear strength than the brass rivets that were used for decades. the average brake lining has at lest 10 or 12 rivets holding it onto the shoe. Also, the pop rivet has a solid shank through it, rather than the hollow brass tubing in a conventional brake rivet. Brass brake lining rivets were made for quick assembly in a production shop, not necessarily maximum strength.
Interesting. So, they'd be OK then? If that's the case I might try to buy the linings and do 'em myself versus $230 at the brake and clutch place. Although in fairness, they do a really nice job.
Look into using "clecos" to hold the linings in place while you're riveting. They're usually used for sheet metal assembly during riveting jobs.
https://www.ebay.com/itm/264684264232?
Linings can also be bonded to the shoes, using thermo-setting cement- - - -2 hours at 400 degrees F.
https://www.ebay.com/itm/256714559357?
