3 members (Gdads51, UtahYork, 1 invisible),
109
Mod | | | Forums66 Topics128,191 Posts1,057,364 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2022 Posts: 52 'Bolter | | 'Bolter Joined: Sep 2022 Posts: 52 | Morning fellow 'Bolters,
I'm coming up empty on my search to find anyone in my region that will re-line shoes and even turn large brake drums. Do any of you have resources that you would be willing to share? The region i'm looking in is NE/SE Kansas, NW/SW Missouri, NE Oklahoma and SE Nebraska.
1951 GMC 451 1964 International Harvester v190
| | | | | Joined: Oct 2023 Posts: 74 'Bolter | | 'Bolter Joined: Oct 2023 Posts: 74 | For turning brake drums, pretty much any industrial machine shop with a large lathe will be able to do it. Try asking some oilfield guys if they know of anyone. | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | Check with your local Big Rig repair shop, they should have a source for brake shoe linings and drum turning. Local car repair garages aren't setup for big truck stuff. Mike B  | | | | | Joined: Sep 2022 Posts: 52 'Bolter | | 'Bolter Joined: Sep 2022 Posts: 52 | I'll be on vacation for Christmas. I'll reach out to some at that time. Thanks
| | | | | Joined: Feb 2004 Posts: 29,885 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,885 | Are your brake linings bonded or riveted to the shoes? I have a shoe riveting machine if you can find the proper linings. There are usually lots of them on Ebay, and the right rivets, at very reasonable prices. On some of the really big rigs (18 wheeler size) the brake blocks are simply bolted to the shoes with pan head screws, with self-locking nuts on the back side. A commercial machine shop with a big lathe and a tool post grinder should be able to clean up your drums. Jerry
| | | | | Joined: Jan 2008 Posts: 4,964 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,964 | I used to turn drums, but we quit doing that a long time ago. I still have the machine. If you have someone turn them, make sure they finish with a grinder. The cutter will hop over hot spots and leave you with an out of round drum. I always finished the job with a grinder to grind the hot spots. If you can't find pads, call San Antonio Brake and Clutch in San Antonio, TX. They go out of their way with obsolete stuff. And UPS shipping on just the pads wouldn't be that bad. And you can either rivet or bolt them on. | | | | | Joined: Jun 2005 Posts: 56 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 56 | You might try Lincoln Clutch and Brake Supply, in Lincoln, NE
WW2Chevy 1942 Chevrolet G506 1-1/2 ton 4x4 Army Cargo w/ winch
(Retro-roco)
| | | | | Joined: Aug 2010 Posts: 608 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 608 | I got mine relined at Brake and Clutch Supply in Seattle, WA. They are really knowledgeable on the old stuff and have vintage linings in stock.
| | | | | Joined: Nov 2004 Posts: 2,423 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,423 | Try this shop Auto Brake and Clutch in Omaha. You can tell them they were recommended by John at Arnold Tool in Council Bluffs. I believe the owners name is Lon. Auto Brake and ClutchJohn
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Feb 2004 Posts: 29,885 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,885 | All that's really needed to reline brake shoes is a drill press, a few small C-clamps, and a pop rivet gun. Maybe a disc sander to radius grind the lining once it's on the shoes. More sophisticated equipment just makes a high volume shop more profitable. Jerry
| | | | | Joined: Aug 2010 Posts: 608 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 608 | Would regular (I assume steel) pop rivets hold up to the heat and not fatigue loose?
| | | | | Joined: Jun 2005 Posts: 116 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 116 | I had a local tractor repair shop reline mine. If there's one in your area, they might be able to do it. | | | | | Joined: Aug 2010 Posts: 608 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 608 | The correct rivets are usually brass or steel, but not pop rivets. I don't know that I would trust pop rivets for this, however I could be wrong and maybe they're fine.
| | | | | Joined: Feb 2004 Posts: 29,885 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,885 | A steel, or stainless steel pop rivet will have much greater shear strength than the brass rivets that were used for decades. the average brake lining has at lest 10 or 12 rivets holding it onto the shoe. Also, the pop rivet has a solid shank through it, rather than the hollow brass tubing in a conventional brake rivet. Brass brake lining rivets were made for quick assembly in a production shop, not necessarily maximum strength. Jerry
| | | | | Joined: Aug 2010 Posts: 608 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 608 | Interesting. So, they'd be OK then? If that's the case I might try to buy the linings and do 'em myself versus $230 at the brake and clutch place. Although in fairness, they do a really nice job.
| | | | | Joined: Feb 2004 Posts: 29,885 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,885 | Look into using "clecos" to hold the linings in place while you're riveting. They're usually used for sheet metal assembly during riveting jobs. https://www.ebay.com/itm/264684264232?Linings can also be bonded to the shoes, using thermo-setting cement- - - -2 hours at 400 degrees F. https://www.ebay.com/itm/256714559357?Jerry
