4 members (Jman, Robert Crandall, Steelonsteel, Wally / Montana), 79 guests, and 3 robots.
Topics128,035
Posts1,055,556
#1577193 05/12/2025 10:51 PM
My left knee does not like shifting any more so it looks like my 37 might get a automatic when I install the new 235,does anyone know if I can use my existing foot stomp starter with the adapter.
What are you planning on using for an automatic transmission?
The short answer is "no". You can use a foot button switch that Steiner Tractor sells for several types of antique tractors along with a solenoid starter to make a very convincing looking fake foot start.
Trans will most likely be a TH 350.
It's wired for a key start but would have been nice to use the foot stomp.
Can you post pics of your adaptor?
One kit I looked up that mates a stovebolt engine to a Chevy V8 pattern automatic trans costs $650.00 and includes a racing type gear reduction starter. I believe I can build one from 3/8" steel plate for under $100.00 that uses the original stick shift flywheel and starter with an automatic trans torque converter.
https://store.tracyvette.com/item/1849/
Have not gotten one yet.
I have built 2 electric stomp starters for 350 v8s in two AD trucks.
One uses a Ferguson 9N starter switch and some various other parts to make it work.
The other one utilizes a micro switch rather than the tractor switch but will require a relay to energize the V8 starter solenoid.
Both of these are self contained inside of the starter pedal bellows (except for the relay for the one with a micro switch).
Both of these switches give you the feel and the looks of the original mechanical starter.
