10 members (sron48, cmayna, Scott, 48jim1ton, frogfarmer, Wayne67vert, Wally / Montana, gswbbc, Gdads51, panel fan),
129
0
Mod | | | Forums66 Topics128,049 Posts1,055,553 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | My left knee does not like shifting any more so it looks like my 37 might get a automatic when I install the new 235,does anyone know if I can use my existing foot stomp starter with the adapter. | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | What are you planning on using for an automatic transmission?
| | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | The short answer is "no". You can use a foot button switch that Steiner Tractor sells for several types of antique tractors along with a solenoid starter to make a very convincing looking fake foot start. Jerry
| | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | Trans will most likely be a TH 350. | | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | It's wired for a key start but would have been nice to use the foot stomp. | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | Can you post pics of your adaptor?
| | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | Can you post pics of your adaptor? One kit I looked up that mates a stovebolt engine to a Chevy V8 pattern automatic trans costs $650.00 and includes a racing type gear reduction starter. I believe I can build one from 3/8" steel plate for under $100.00 that uses the original stick shift flywheel and starter with an automatic trans torque converter. https://store.tracyvette.com/item/1849/Jerry
| | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | Can you post pics of your adaptor? Have not gotten one yet. | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | I have built 2 electric stomp starters for 350 v8s in two AD trucks.
One uses a Ferguson 9N starter switch and some various other parts to make it work.
The other one utilizes a micro switch rather than the tractor switch but will require a relay to energize the V8 starter solenoid.
Both of these are self contained inside of the starter pedal bellows (except for the relay for the one with a micro switch).
Both of these switches give you the feel and the looks of the original mechanical starter.
