7 members (Bill Hanlon, Otto Skorzeny, 52Carl, Hotrod Lincoln, TooMany2count, chemanic, 1 invisible), 96 guests, and 2 robots.
Topics128,135
Posts1,056,418
Members48,441
#157522 01/15/2006 10:36 PM
What are these bolt heads I'm seeing on my newly acquired truck, like the ones attaching the rear fenders to the bed sides? Where can I pick up a set of sockets that fit those?
Thanks.
David
1950 Chevrolet 3100 "One Step Forward, Two Steps Back"
Webshot Photos
#157523 01/15/2006 11:17 PM
Red,
If you are talking about the style of bolts that look like a mini fig 8.......They are Clutch Head.
Most of the vendors carry a set of them,for the sizes that you will need,in screwdriver style.
Any decent tool supply will carry them also wink
#157524 01/16/2006 12:36 AM
Junior Member
Junior Member
ace hardware sells the clutch head bits
#157525 01/16/2006 12:37 AM
Sears tools and Auto parts NAPA stores can get them for you. Also the Filling Station www.fillingstation.com or Chevy's of the 40's have them.
34 & 35 trucks are the greatest
#157526 01/16/2006 2:14 AM
A good tool is a impact socket driver in 3/8 size and buy your clutch head bits to match along with the clutch head screwdriver set and you will be good to go!!! The clutch head bits for the 3/8 driver will fit your standard 3/8 rachet and that gives you a lot of versitilty.
Hobert
"The Lord is my shepherd"
#157527 01/20/2006 3:32 PM
I searched for quite a while online yesterday. I found and bought some clutch head screwdrivers, but could only find the bits in the smaller sized heads with a 1/4" shaft. I found nothing in the 3/8" shaft size and 5/16" head size. I'll keep looking but figure I'll have to make due with the screwdrivers for the larger size.
Webshot Photos
#157528 01/20/2006 4:22 PM
need to search in all the right places: set of 4, up to 5/16 - all the GM repro suppliers have'em, and other styles [bits only] are available from SnapOn and other tool dealers
#157529 01/21/2006 4:42 PM
Set of 5 clutch-head tips/bits with holder from Chevs of the 40's. They also sell the separate bits. I like the bits because you can also use them with a ratchet or with other handles/drivers.
Tim
#157530 01/23/2006 3:51 PM
Thanks, tclederman. That's exactly what I was looking for. I'll put an order in right now.
Webshot Photos
Moderated by  MNSmith
