4 members (Robert Crandall, Hotrod Lincoln, 3800GUY, 1 invisible), 69 guests, and 2 robots.
Topics128,082
Posts1,055,961
Members48,430
#1573912 03/30/2025 4:35 PM
When my 37 gets the new 235 this year I want to install the oil filter again,when I put togather the present 235 I used hoses I could locally find and I think the internal size was too big since when I removed the filter the oil pressure went up a bit so is there ant vendors that sell the correct hoses. I picked up another 235 but as soon as the hoses were touched they broke.
Jim Carter and the rest of the restoration supply places sell them. You can also take your old ones to a local hydraulic shop and have copies made. I think the fitting has a restrictor in it reducing it to 1/8" or something like that.
Do you still have your old ones?
1950 Chevrolet 3100 (Ol' Roy)
7
7 Offline
The diameter of the hose won't change the pressure, it is the restrictor that has the job of regulating how much volume goes to the filter. If the ID of the hose is determined by the size of the fittings on each end, then stay with that diameter, just try to duplicate the restrictor.
H Online: Content
Most bypass filters with the 1/16" restrictor hole in the standpipe will drop hot oil pressure by about 5 PSI on an engine with proper clearance on the rod and main bearings. That's not enough to be concerned with, and it wouldn't matter if your filter hoses were an inch in diameter. That would just add a bit of volume to the oil capacity.
