0 members (), 77 guests, and 1 robot.
Topics128,030
Posts1,055,428
Members48,422
#1570802 02/20/2025 2:35 PM
I am curious about the cigarette lighters ,are there 6 volt and 12 volt or are they the same .I would like to put one in my truck to power or charge phones ect. Has anyone installed and used one for powering phone chargers?
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
7
7 Offline
I put one in my '57, just a universal unit. I can use it for the GPS or phone or spotlight, etc.
The socket is the same. The heating element in the actual cigarette lighter is different between 6v and 12 volt.
I use mine to charge phones, ear pods and previously an old Garmin GPS unit. I fused the lighter socket at 5 amps to support these smaller loads and then ripped the heating element out of the lighter to insure someone wouldn't push it in which would cause the small fuse to blow.
back yard wrench turner
I added a 12 volt combo unit to my '38. It's a power outlet and a usb dual charger with 3.0 charging.
I have used it to power a bluetooth speaker when I do Little Blue Truck days.
I also added a switch to turn the unit off when the truck is parked and not in use to prevent battery drain.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Very convenient phone charger for those long hauls.
Craig
2 Offline
The generic socket at oreilly auto parts fit very well in my 1950 looks virtually identical to the original, the chrome ring maybe slightly different width maybe but you canโ€™t tell.
The original 6v lighter can short this new socket out however
I did have to modify it slightly
But it likely would be fine as is for all modern things that plug into it with a plastic body.
-s
๐Ÿ‘ good imfo I have one in a box somewhere going to take a look ,Anyone know what the difference is in the element part ,I am not a smoker and with the imformation provided by Bill I will most likely take the element out and put the fuse in .Kevin
"The Journey"
Follow in the DITY
