3 members (Phak1, Shade Baby, TPR57C), 87 guests, and 2 robots.
Topics128,157
Posts1,056,877
Members48,458
Hello,
Is a split distributor shaft a normal part in 292ci truck engines? I bought a new HEI distributor. The new one´s shaft is solid one piece.
1947 Chevrolet 3800 1-ton long bed
292 cui, GM 14 bolt rear-end, 4 x disc brakes
In Frankfurt, Germany
Pictures in the Forum Gallery
Both styles of shaft have been used pretty much interchangeably in 230, 250, and 292 engines. I'm partial to the solid shaft models, as I've seen a couple of sectional shafts break when a high volume oil pump is used. A small modification of the housing is necessary if the HEI is used in a 216, 235, or 261 engine to make sure the oil pump drive and drive gear engagement is at the correct depth.
Thank you Jerry!👍
