| | | Forums66 Topics128,130 Posts1,056,702 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2024 Posts: 126 'Bolter | | 'Bolter Joined: Mar 2024 Posts: 126 | Hello I am putting in my 4 speed with carrier bearing. I have ran into a problem with the rear end yoke is smaller on my 55 2nd series than the 55 1st series that I took the 4 speed and the two drive shafts.
My 55 2nd has a 3 1/2 inch with a 1 1/16 x3 3/16 u-Joint
The 55 1st series has 3 3/16 x 3 5/8 or 11/16
The question is does the first and second series have the same yoke spline will they enter change ? That would be for the pinion gear spline
Thanks for any help
P.S drive shaft on 2nd series is 3 1/2 the first series is 2 1/2
1955 second series 3200
| | | | | Joined: May 2015 Posts: 11,113 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,113 | An easy fix might be a replacement u-joint cross that has different bearing dimensions on each end. They should be available fairly readily at a driveline shop. That way you don't need to mess with the pinion yoke and possibly mess up the bearing preload. This might help you out. Click on the style of u-joint you have and it'll take you to dimensions. [on edit] Are both trucks the same series? 3200 and 3200? [another edit] They can't be, as the 55.1 series didn't have a 3200.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2024 Posts: 126 'Bolter | | 'Bolter Joined: Mar 2024 Posts: 126 | I will look at site. And to answer your question no I believe it is a 3800 2 ton oor 1 1/2 ton I just went and took the yoke off it is a 11 spline..
My 55 first series was a 3600 3/4 ton with a 4 speed great truck drove it for almost 10 years.
So what you are saying is they make a u-Joint that has make. 1 1/16 x3 3/16 x1 3/16 x3 11/16 on the other that would be awessom.
Thanks Kevin
Mike
| | | | | Joined: May 2015 Posts: 11,113 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,113 | Yes, there are u-joints that have different bearing cup diameters match up with different size yokes.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2023 Posts: 103 'Bolter | | 'Bolter Joined: Feb 2023 Posts: 103 | Type “MOOG universal joints (U- joints) by size” into your favorite browser, open to view. Scroll down their excellent chart. You can select the size required for each bearing cup and they provide a part number that will do the job.
1954 Chevy 1300 engine 235 (1959) 1955 (first series) Chevy 3100 engine 261 (1957) 1927 (other brand) Model T- engine 327 (1968)
| | | | | Joined: Mar 2024 Posts: 126 'Bolter | | 'Bolter Joined: Mar 2024 Posts: 126 | perfect thank you so much Merry Christmas
| | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | AD 3800 trucks and many, many 3/4 and 1-ton trucks since use a series 1350 Spicer U-joint. The next size up is 1420 but I don't know the dimentions off hand. If you need a different joint on either end the driveline shop can cut, weld and balance the shaft with the yoke you need. Unless it's an expensive part like a slip joint, it won't cost much. I don't know if Moog uses the same numbering system. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: Mar 2024 Posts: 126 'Bolter | | 'Bolter Joined: Mar 2024 Posts: 126 |
