2 members (59 fleet, KEVINSKI),
157
Mod | | | Forums66 Topics128,034 Posts1,055,551 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 16 New Guy | | New Guy Joined: Jan 2009 Posts: 16 | I need seats for a 52 gmc can anyone tell me what might fit? buckets would be great but from what vehicle | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | 2001 and buick lesabre. i have them in my 54. has built in shoulder harness and 60/40 with arm rest.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I used late model S-10 seats in my 55,a nice set of 60-40 seats,that should fit you GMC. | | | | | Joined: Mar 2009 Posts: 208 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 208 | how much modification is needed to bolt down the seats? buick or s10? Not to hijack your post - but I'm looking into the same thing & don't have the welding skill to fab too much in the way of brackets. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | hey Midget, might consider some 60/40 GM truck seats [mid 80's], just hafta drill some holes in the floor Bill | | | | | Joined: Mar 2009 Posts: 208 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 208 | thanks squeeze - Do you need to remove the gas tank or will new seats work with it still in place? | | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 |
| | | | | Joined: Mar 2009 Posts: 208 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 208 | Avette4me - that turned out really nice! That is the type of thing I'm looking to do.
I like the old look, but need good seat belts. My wife however won't ride in it if it stinks like an old truck - so I was thinking a nice set of new leather or cloth seats from a modern car & some new carpet & she would be able to ride with me.
thanks | | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | Thanks.
If you want newer seats, I believe you'll discover that most any that you find can be made to work.
I think you've got about 58" in width (off memory, but you can measure) and a mostly flat floor so the most work you should have to do is make pedestals. They can be made from square tube - about 2" wide X however tall you need them. You make 4 per seat to bolt in a 4 point position. They're easy to bolt to the floor, then bolt the seats to them, or vice versa if you prefer. As long as the seats have a platform that's bottom is flat, it a pretty straight forward mod.
| | | | | Joined: Mar 2009 Posts: 12 New Guy | | New Guy Joined: Mar 2009 Posts: 12 | I found some 1998 Toyota Sienna leather electric seats at a boneyard. They work and fit with room to spare in my 49 Chevy 3100. Mas gas is already out, so there is room for the seats. Any buckets around 22" to 24" wide and not more than about 26" deep should work fine. You have about 52" width max in my 49 to play with and that leaves room for a small console between the seats.
Good luck, Mike | | | | | Joined: Sep 2012 Posts: 217 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 217 | Just got pair of 2016 4 Runner pwr both sides. About 22 inches which will work and leave space for a console I want to put there. Got to cover and shape like I want off the original frames. Biggest challenge is reworking the floor braces for a flat floor pan got to lift the seat up. I moved my tank out of the cab also. Seems the supply available makes them reasonable price wise. | | | | | Joined: Sep 2009 Posts: 5,793 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,793 | vettecrazy, Just a note that you are replying to a 15 year old thread. The original poster hasn't been active since 2013.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
