BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
1 members (Danielbolt),
487
robot. | Key: Admin,
Mod | | Forums66 Topics126,777 Posts1,039,267 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Nov 2024 Posts: 12 'Bolter | 'Bolter Joined: Nov 2024 Posts: 12 | Does anyone have a picture of the original push button starter Switch for a 1954 GMC 100 with the Hydramatic trans- mission. Also, I don’t really know which dash-hole it Goes into. I’m new here and just bought the truck I’m inquiring about. I’ve got a bunch of questions, just thought I’d start with this one. Thanks. | | | | Joined: Dec 2002 Posts: 3,374 Moderator - The Electrical Bay | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,374 | Welcome to the 'bolt, please go to the welcome forum and introduce yourself and your truck. We also love to see pictures!!!
| | | | Joined: Nov 2024 Posts: 12 'Bolter | 'Bolter Joined: Nov 2024 Posts: 12 | Ok, thanks. I’ll try to get some photos posted. | | | | Joined: Feb 2004 Posts: 28,674 Kettle Custodian (pot stirrer) | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 28,674 | The start switch is a simple chrome push button about 1/2" in diameter with two wire terminals on it. It is usually mounted on the extreme left side of the dash. You'll need to use something like a marine rated high amperage switch, as the momentary current draw of the pull-in winding of the starter solenoid is around 40 amps. Be sure to wire the circuit through the neutral safety switch to avoid starting in gear. Jerry
| | | | Joined: Nov 2024 Posts: 12 'Bolter | 'Bolter Joined: Nov 2024 Posts: 12 | Ok, thanks for that information. I think it goes through a starter relay on the firewall, but not for sure-waiting On a book I ordered for the exact wiring diagram. | | | | Joined: Feb 2004 Posts: 28,674 Kettle Custodian (pot stirrer) | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 28,674 | This one resembles the original equipment switch very closely, but it's only rated for 15 amps. I'd suggest using it in combination with a solenoid switch mounted on the firewall near the starter motor. www.ebay.com/itm/122828881524?Jerry
| | | | Joined: Nov 2024 Posts: 12 'Bolter | 'Bolter Joined: Nov 2024 Posts: 12 | Thanks for that link, I’ll get one ordered. Its hard to Find photos of some of the odd parts for the hydra Matic truck for some reason. | | | | Joined: Feb 2004 Posts: 28,674 Kettle Custodian (pot stirrer) | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 28,674 | Here's a suitable solenoid if you're running 12 volts. Similar designs are also available for 6V operation. Where is Wadley AL located? I'm just above the Alabama state line near I-65, about 40 miles NW of Huntsville. www.ebay.com/itm/375086569284?Jerry
| | | | Joined: Jan 2022 Posts: 1,986 'Bolter | 'Bolter Joined: Jan 2022 Posts: 1,986 | If you have a stock working neutral safety switch like Jerry mentions above, use it. If you don't and have a really hard time finding one, expand your search to include switches from 1952-56 Pontiac and Oldsmobile switches from cars using HydraMatic transmissions. Added bonus is that those switches came with a third terminal to operate backup lights. I had one from a 54 Olds in my 57 GMC.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | Joined: Nov 2024 Posts: 12 'Bolter | 'Bolter Joined: Nov 2024 Posts: 12 | Thanks for all the good information. Wadley is about 50 miles north of Auburn University. | | |
