Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
1 members (Danielbolt), 479 guests, and 1 robot.
Topics126,777
Posts1,039,267
Members48,100
Most Online2,175
Jul 21st, 2025
#1563555 11/19/2024 3:12 AM
0
0 Offline
Does anyone have a picture of the original push button starter
Switch for a 1954 GMC 100 with the Hydramatic trans-
mission. Also, I don’t really know which dash-hole it
Goes into. I’m new here and just bought the truck I’m inquiring about. I’ve got a bunch of questions, just thought
I’d start with this one. Thanks.
Welcome to the 'bolt, please go to the welcome forum and introduce yourself and your truck. We also love to see pictures!!!
Another quality post.
Real Trucks Rattle
0
0 Offline
Ok, thanks. I’ll try to get some photos posted.
H Online: Content
The start switch is a simple chrome push button about 1/2" in diameter with two wire terminals on it. It is usually mounted on the extreme left side of the dash. You'll need to use something like a marine rated high amperage switch, as the momentary current draw of the pull-in winding of the starter solenoid is around 40 amps. Be sure to wire the circuit through the neutral safety switch to avoid starting in gear.
0
0 Offline
Ok, thanks for that information. I think it goes through a starter relay on the firewall, but not for sure-waiting
On a book I ordered for the exact wiring diagram.
H Online: Content
This one resembles the original equipment switch very closely, but it's only rated for 15 amps. I'd suggest using it in combination with a solenoid switch mounted on the firewall near the starter motor.
www.ebay.com/itm/122828881524?
0
0 Offline
Thanks for that link, I’ll get one ordered. Its hard to
Find photos of some of the odd parts for the hydra
Matic truck for some reason.
H Online: Content
Here's a suitable solenoid if you're running 12 volts. Similar designs are also available for 6V operation. Where is Wadley AL located? I'm just above the Alabama state line near I-65, about 40 miles NW of Huntsville.
www.ebay.com/itm/375086569284?
If you have a stock working neutral safety switch like Jerry mentions above, use it. If you don't and have a really hard time finding one, expand your search to include switches from 1952-56 Pontiac and Oldsmobile switches from cars using HydraMatic transmissions. Added bonus is that those switches came with a third terminal to operate backup lights. I had one from a 54 Olds in my 57 GMC.
0
0 Offline
Thanks for all the good information. Wadley is about
50 miles north of Auburn University.
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.151s Queries: 14 (0.112s) Memory: 0.6393 MB (Peak: 0.7234 MB) Data Comp: Zlib Server Time: 2025-09-22 05:04:56 UTC
Valid HTML 5 and Valid CSS
