8 members (55shaker, MickeyP, Bill Hanlon, 3B, Gdads51, Ridgeback, Gray_Ghost, 32Fordpuchoptop), 112 guests, and 1 robot.
Topics128,118
Posts1,056,304
Members48,439
I'm looking for a crankshaft main bearing set for a '54 to early '55 235 engine. This is the dowel pin mounted style. I need .010 under size. The brands and part numbers I have are as follows. Federal mogul 853m010, Clevite MS189P 010, michigan ms1690p010 any one know were I might find these for sale.
Moderator, Electrical Bay
Those are very hard to find and quite expensive, Miller. You probably would be better advised to use a Dremel tool and cut notches so the later type bearings could be used instead. Jerry (HotRodLincoln) can help with this.
~ Jon
Send me a PM and I'll respond with a phone number. it's easier to discuss the procedure in a 2-way conversation. The whole job takes less than an hour with a bare block to work with. After the modification the later model 56-63 mains will be a drop-in fit.
No contact- - - -I guess he's not interested!
1 Offline
Well.... Maybe this was a pinch. In a pinch I've shimmed main bearings to get reduced clearance after taking out the factory shims under the caps. Ive also filed rod caps when there were no more shims to take out of babbited rods and I couldn't afford rods. A new set of rods was more than the $10 I paid for my 41 deluxe coupe. It got me to school and back even so.
1951 3800 1-ton
In the DITY Gallery
We finally made contact, and I've outlined the procedure for modifying the early 235 block to use the later model, more affordable main bearings. It takes less than an hour, and a few strategic cuts made with a Dremel tool.
Jerry,
I am in the exact problem with my 1954 235 rebuild as I can not find the main bearings anywhere. Can you share the procedure with me too?
Thanks Jerry
Butch
Send me a private message and I'll respond with a phone number. The procedure for fitting the late model bearings is best discussed in a 2-way conversation, not by text.
Thanks Jerry, I sent you a message.
Butch
