| | | Forums66 Topics128,079 Posts1,056,286 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2021 Posts: 27 'Bolter | | 'Bolter Joined: Jul 2021 Posts: 27 | I'm looking for a crankshaft main bearing set for a '54 to early '55 235 engine. This is the dowel pin mounted style. I need .010 under size. The brands and part numbers I have are as follows. Federal mogul 853m010, Clevite MS189P 010, michigan ms1690p010 any one know were I might find these for sale. | | | | | Joined: Mar 2014 Posts: 4,502 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,502 | Those are very hard to find and quite expensive, Miller. You probably would be better advised to use a Dremel tool and cut notches so the later type bearings could be used instead. Jerry (HotRodLincoln) can help with this.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Feb 2004 Posts: 29,821 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,821 | Send me a PM and I'll respond with a phone number. it's easier to discuss the procedure in a 2-way conversation. The whole job takes less than an hour with a bare block to work with. After the modification the later model 56-63 mains will be a drop-in fit. Jerry
| | | | | Joined: Feb 2004 Posts: 29,821 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,821 | No contact- - - -I guess he's not interested! Jerry
| | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | Well.... Maybe this was a pinch. In a pinch I've shimmed main bearings to get reduced clearance after taking out the factory shims under the caps. Ive also filed rod caps when there were no more shims to take out of babbited rods and I couldn't afford rods. A new set of rods was more than the $10 I paid for my 41 deluxe coupe. It got me to school and back even so. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: Feb 2004 Posts: 29,821 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,821 | We finally made contact, and I've outlined the procedure for modifying the early 235 block to use the later model, more affordable main bearings. It takes less than an hour, and a few strategic cuts made with a Dremel tool. Jerry
| | | | | Joined: Aug 2005 Posts: 26 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 26 | Jerry,
I am in the exact problem with my 1954 235 rebuild as I can not find the main bearings anywhere. Can you share the procedure with me too? Thanks Jerry
Butch | | | | | Joined: Feb 2004 Posts: 29,821 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,821 | Send me a private message and I'll respond with a phone number. The procedure for fitting the late model bearings is best discussed in a 2-way conversation, not by text. Jerry
| | | | | Joined: Aug 2005 Posts: 26 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 26 | Thanks Jerry, I sent you a message.
Butch | | |
