2 members (TUTS 59, Wayne67vert), 118 guests, and 1 robot.
Topics128,035
Posts1,055,549
Members48,425
#1559285 09/29/2024 1:11 PM
Anyone have experience with modified 22.5 10 bolt wheels? I found a shop to put new centers on but I’m not sure what width 22.5 wheels to get. I’ve read the wheels and tires links but if it is in there, I missed it several times. I would consider multi-piece wheels if I can mount them myself. Locally they want $80/tire to mount multi-piece wheels. 19.5s are just too small.
Suggestions? Possible sources for multi-piece?
1954 Chevy custom 261CID, T-5 5 Speed.
1952 Chevy 6400 2 ton hydraulic flat bed.
Crusing in the Passing Lane
Wheel width can be determined by tire selection, 9 x 22.5” tires have a desired width, probably 6 or 7”, however they can be mounted on 5.5” original wheels. Check with your tire supplier.
Picture shows 9 x 22.5” tire on ‘60’s GMC 7” wide rim redrilled to 10 on 7.250.
Ed
7
7 Offline
My original 22.5 tubeless rims are 7", running 235/80/22.5 and 10R/22.5 on them with no bulging.
My concern is that 22.5 wheels come in so many widths I’m afraid to get too wide and have them hit something underneath in a turn. I found some and they had so many widths I didn’t know what to do.
Pick all the same!
Ed
What size tires do you want to use? That is what will determine the width of the wheel. In addition to wheel width, you must take offset into consideration.
7
7 Offline
The 10R22.5 is a BIG tire, as you can see in the pictures of my '57 2 ton LCF. I wanted as big a diameter as possible on the drives to help keep the rpm down on the road. The 235/80/22.5 will just touch the drag link on a right turn if the steering is up against the stop. I'll measure them and edit this post, you can also Google a tire chart to find the dimensions of various tire sizes. Edited= With my truck parked on concrete and roughly 1000 lbs. in the bed, rear tires (10R22.5) are 39" tall, fronts(235/80/22.5) are 36"
I just want a tire that won’t look tiny like the 19.5 does. I was surprised at how many widths I found. The stock 20” are about 38” tall, 19.5 is 34” tall.
9 x 22.5” are the smallest modern tubeless tires that will fill out your wheel well!
Ed
My '50 COE has 22.5" wheels that are 6.75 width. Tires are 9R22.5.
Kent
PS That size tire is the same radius/circumference as the original 8.25x20 bias tire. Therefore, gear ratios and speedometer response are same as new.
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Tubeless tire (22.5") and tube type tire (20") size numbering systems are not equal, they are one size offset for each other...
These tires have the same diameter and can be rum side by side; I noted the rim width for the 22.5 only
8.25 x 20 = 9.00 x 22.5 (6.75" wide rim)
9.00 x 20 =10.00 x 22.5 (7.5" wide rim)
10.00 x 20 = 11.00 x22.5 (8.25" wide rim)
11.00 x 20 = 12.00 x 22.5 (9" wide rim)
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thanks Mike B, that is exactly what I was looking for.
