0 members (), 108 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
#1559702 10/03/2024 9:18 PM
Just some info on my stupid experience. I replaced my 216's head last summer and have been on and off trying get it to run smoothly. I adjusted the valves several times, worked with the timing, even replaced the carb. Today I went to get non-ethanol gas for winter storage. I still had an intermittant "pop" in the exhaust. Figured I'd double check the valve adjustment again. This time I noticed that the front bolt holding the rocker assembly was loose. I could actually wiggle the rocker shaft. Tightened the bolt, readjusted #1 and #2 valves and now it is running better than it has in literally years. I don't know how I never noticed that loose bolt, I know I torqued it when I swapped the head last summer - but I never re-checked it. Just goes to show - aargh. Easy simple thing I never checked - double arrgh!
But at least you found and corrected it. Good for you. Now take the rig out for a celebration/test drive.
Craig
There may be a reason it was loose besides just missing it. Drive it and later I'd suggest a recheck.
Insomniac
Insomniac
Didn't know they could get loose. Maybe a good thing to check before adjusting the valves...
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Elderly bolts can, and do stretch. I'd suggest replacing those rocker stand bolts with 3/8-16 Allen head cap screws, which are available on Ebay in a wide variety of lengths. Fastenal will probably have appropriate length new studs for the valve cover attachment on the 216/early 235 engines.
Elderly bolts can also snap unexpectedly when torquing them. I've had that happen on occasion at well below the spec'd torque.
