2 members (Hotrod Lincoln, 1 invisible),
137
Mod | | | Forums66 Topics128,196 Posts1,057,385 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2014 Posts: 305 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 305 | I was wondering on a Chevy 1951 216 if the valves are stuck will the piston hit it and damage the valves
| | | | | Joined: Oct 2014 Posts: 120 'Bolter | | 'Bolter Joined: Oct 2014 Posts: 120 | There should not be a problem with pistons striking valves in 216 or 235 engines. In stock configuration, these are non-interference engines.
1955 1st Series 3100 ol'55 | | | | | Joined: Feb 2004 Posts: 29,885 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,885 | A 235 can have interference problems between the connecting rod bolts and the camshaft core if the cam gets out of time, but they have a longer stroke than a 216. I don't believe a 216 will have any risk of contact anywhere, including the valves. Jerry
