| | | Forums66 Topics128,007 Posts1,055,275 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Has anyone seen or have knowledge of a tool that clamps to a spindle and starts re-threading from the inner part of the spindle threads to the outter edge of the threads?
| | | | | Joined: May 2001 Posts: 477 Shop Shark | | Shop Shark Joined: May 2001 Posts: 477 | come to think of it --yes. there is a local company called axle surgeons. they do this type of work plus restore rear axles that have seen bearing failure. mostly for big trucks, and the service is portable---they can do it on the side of the road.  | | | | | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | I've seen those ads too for the axle repair in big truck books free at truck stops. They can even cut off the whole bearing spindle on back axles and weld on new, amazing! Maybe that's how they fix some of the ones they do with that Magic tool! I've never heard of anything like it 'cept that thread chaser like in Northern catalogs! Can't be too good of tool from them!  :rolleyes:
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
